emergency brake assistance
Has thanked: 1 time
Been thanked: 10 times
Post by GARYSCC »
I am trying to figure out how to connect my e brake. It seems like my rod is not correct for my 1967?
Has thanked: 6021 times
Re: emergency brake assistance
Gary, it looks correct to me. The only picture I have at hand is the following:
I can measure tomorrow the length so you can compare with yours, but I'm sure it's correct.
Has thanked: 7718 times
Esteban beat me to it. :D
The rod is correct for your '67. The rods didn't change between years, pretty much nothing did on the hand brake. I can see that you will still be missing the adjustment bolt that is the smaller one to the right of the larger one with the spring on it.
Has thanked: 1 time
Post by GARYSCC »
Ok now I see how it works. Is that small adjustment bolt complex or can jerry rig something?
Has thanked: 310 times
Been thanked: 176 times
Post by bosque »
Sounds like you have a handle but......haha ebrake.....handle...... :roll:
Has thanked: 1 time
Post by GARYSCC »
haha. thanks again Esteban & Leslie - the picture and info was very helpful. Leslie had given me the the diagram previously, but I just didn't understand how it worked until I saw the color photo. Is the little bolt and spacer an important part of it to work? If so, should I try to find one on ebay or from one of you guys? Or, do you suggest I make one up myself?
GARYSCC wrote:haha. thanks again Esteban & Leslie - the picture and info was very helpful. Leslie had given me the the diagram previously, but I just didn't understand how it worked until I saw the color photo. Is the little bolt and spacer an important part of it to work? If so, should I try to find one on ebay or from one of you guys? Or, do you suggest I make one up myself?
You can make one yourself. After reading your post and looking at my picture, mine clearly looks fabricated. Have forgotten about it. ;) ;)
I agree with Esteban. Just find a bolt long enough and use 2 nuts on the end to lock the adjustment. This is one of the 3 adjustments for the handbrake shoe.
Has thanked: 84 times
Been thanked: 327 times
Post by miller »
Esteban wrote:I can measure tomorrow the length so you can compare with yours
bosque wrote:Sounds like you have a handle but......haha ebrake.....handle...... :roll:
:laughing-rolling: ahh what a great start to my day
Has thanked: 1 time
Post by GARYSCC »
Hi, I noticed my shoe was upside down with the correct picture so I rotated it and re installed it. Its all done except the rod is is too long as shown. Were there shorter wheelbase patrols made? It looks like I will need to shorten my rod by several inches. Any thoughts?
