Heater Vent hoses & fresh air intake hose
Original and compatible parts
Has thanked: 310 times
Been thanked: 176 times
Post by bosque »
I will add a shot of the fresh air hose (3"-3 1/2" from Gates also) when I find it. This hose is not original but looks very good and close. The original vent hose was spring wrapped with canvas.
Has thanked: 69 times
Been thanked: 84 times
Re: Heater Vent hoses & fresh air intake hose
Post by Urban60 »
bosque wrote:I will add a shot of the fresh air hose (3"-3 1/2" from Gates also) when I find it. This hose is not original but looks very good and close. The original vent hose was spring wrapped with canvas.
You can use your own springs and use some of this 2" Fabric Heat Shrink Tubing it looks like canvas and it comes in 6' lengths
http://www.ebay.com/itm/JEGS-Performanc ... 4851cc2f35
Audrey
Has thanked: 7728 times
Do you have a picture of the finished product? :clap:
Post by Urban60 »
RiverPatrol wrote:Do you have a picture of the finished product? :clap:
I will get one! I am in the process of putting it back together.
Audrey
zed
Has thanked: 203 times
Been thanked: 680 times
Post by zed »
Audrey,
Do you have a photo of the hose?
Thanks,
Post by Urban60 »
I will take photos tomorrow. :roll:
Audrey
Post by Urban60 »
Here are some pictures not a perfect solution. If the coil is all beat up I would not recommend this because every imperfection shows when it shrinks into the voids. You can use the fabric heat shrink just to repair over your existing hose material but you will be trapping in years of dirt. The rubber connectors are trashed on mine so I bought some hose reducers but they can get pretty expensive.
1786
1785
1788
1787
Audrey
Post by bosque »
Urban60 wrote:Here are some pictures not a perfect solution. If the coil is all beat up I would not recommend this because every imperfection shows when it shrinks into the voids. You can use the fabric heat shrink just to repair over your existing hose material but you will be trapping in years of dirt.
You could wrap the new gates brand with the shrink "mink coat"! ;)
Post by Urban60 »
Yes! that works also ;)
Audrey
Post by bosque »
Just more shots of original equip. on a '65 I was into today......
