Does anyone have the measurement for the distance between ground and fender lip (both front and rear) of the L60/G60 Patrol?
(Presume the vehicle is unladen with passengers or cargo and all fluids are at full capacity Additionally, presume the wheel and tires are the original 7.50x15 or 7.50x16 specification.)
Thanks,
Original spring height
- Has thanked: 203 times
- Been thanked: 680 times
- Has thanked: 6023 times
- Been thanked: 1605 times
Re: Original spring height
Keith, in the Service_Manual_Nissan_Patrol_Model_60_Series.pdf, on page 23 of the scan, or 20 printed in the manual, you have some dimensions that will help. However this are for the older models, but will be a good reference.zed wrote:Does anyone have the measurement for the distance between ground and fender lip (both front and rear) of the L60/G60 Patrol?
Thanks,
http://www.60patrol.com/forum/viewtopic.php?f=30&t=1670
No measurements to the fender lip. But there are measurements to the center line of the lights, as follow:
To center line of front turn lights: 915mm (36")
To center line of headlams: 935mm (36-13/16")
To center line of rear lights: 765mm (30-1/8")
To bottom of licence plate light: 1045mm (41-1/8")
Note: the measurements are for the 60 model. Canvas top. I know that in your case, specially with the rear lights, there might be a problem.
If you need this page at a bigger scale, let me know.
- Has thanked: 149 times
- Been thanked: 310 times
I know you guys don't have heavy duty patrols but my books don't give us a listing for g60-H ride height, can someone please chime in
You don't miss a chance to rub it in...G60michael wrote:I know you guys don't have heavy duty patrols but my books don't give us a listing for g60-H ride height, can someone please chime in
It is on page 25. Since the numbers are somehow difficult to read, here they are:
Measurements for the G60H
To center line of front turn lights: 935mm (36-13/16")
To center line of headlams: 955mm (37-9/16")
To center line of rear lights: 800mm (31-1/2")
To bottom of licence plate light: 1080mm (42-1/2")
Please note that this manual probably was published 1962 or 1963. They don't have measurements for the hard top models. So this numbers should serve as a reference only.
Looking for something else, I found that this Service Bulletin has all the information regarding heights. It will be more exact ones for Zed's.
Service_Bulletin_Apr_1968.pdf
http://www.60patrol.com/forum/download/file.php?id=21
It's located at the Patrolabiblia, Service bulletins for the L60 Patrol:
http://www.60patrol.com/forum/viewtopic.php?f=30&t=1681
There's additional information there that's good reading.
Esteban,
Thank you. (If only the IRS could provide this level of service, then my job would be so much less stressful!)
