freeing siezed brakes
Has thanked: 149 times
Been thanked: 310 times
Post by G60michael »
Hi all, got the diff from neils SWB G60, to put into the Ute.
Had one side (passenger) turning, it was hard, but some driving will free it up, managed to get the other side (drivers) turning now, pretty good.
Now the problem is the other side i first got moving (passenger) is frozen up and cannot get it moving again, its only stopped moving since i got the other side (drivers) moving
Help needed ASAP, Plan to get diff sorted,
Cheers heaps
Has thanked: 7721 times
Re: freeing siezed brakes
What have you tried so far? Have you backed off both adjusters yet? Have you tried removing the brake drum?
RiverPatrol wrote:What have you tried so far? Have you backed off both adjusters yet? Have you tried removing the brake drum?
Undone both adjusters on jammed wheel, tried to remove drums, but i think its on there for good
