USA Patrol Registry
Has thanked: 97 times
Been thanked: 568 times
Re: USA Patrol Registry
Post by jwgreen »
RiverPatrol wrote:
jwgreen wrote: Where is the frame # usually located??
If you open the hood and lean over the right fender, look down. It will be on top of the frame rail about even with the exhaust pipe. You might need to clean some gunk off of it to read it.
Leslie,
I did as you said and I REMOVED the hood and the RIGHT FENDER and found the number!! ;) ;)
L60-27L82
That's what you said right?? ;) :lol:
Has thanked: 7711 times
Hahaha! :lol: :lol: :lol: I guess I should be a little more careful with my explanations from now on.
Your's and 67NissanPatrol67's have been added to the Registry.
Has thanked: 351 times
Been thanked: 301 times
Post by mdawg4x4 »
Leslie,
L60-27L82
Now that is removing the fender right there! :)
Has thanked: 3 times
Been thanked: 12 times
Post by alber garage »
RiverPatrol,
I see 13 patrols on the list that belong to you. Is that correct? That's crazy. Do you actually have all those? Do you have a picture of all your patrols together?
Thanks,
Steve
Steve
Only 13!? There are 4 missing then. :? I'll have to go through and see which one's didn't make it. Actually, since it is the US Patrol Registry I can think of 3 that I wouldn't have included because they weren't originally form the US. So I need to find the other missing 1.
No, I don't have a picture of them all together. I don't think I ever had them all in the same place at the same time. The best I can do is the montage:
Has thanked: 529 times
Post by 50car »
hmmm.... at this rate, it will take me a while to match your numbers... :shock: :)
Jeff
50Car
50car wrote:hmmm.... at this rate, it will take me a while to match your numbers... :shock: :)
I've given up at 3... :lol:
Has thanked: 10 times
Been thanked: 17 times
Post by Keith »
1962 Hard Top L60-2-00675 P18830 Berryville,AR Danette&Keith
1967 Hard top L60-09862 VIN tag only no Patrol Berryville, AR
1969 Hard top KL60-27924 P70895 Berryville,AR Danette&Keith
This is the only two Patrols I own, The 67 is a tag only. It was used by p.o. to title my 69. Any other listed with danette&Keith were by defualt. I was an admin for npca. The way the Registry was setup was that who ever entered the info was named as the owner. I added alot of VIN from ebay or people who contacted me. Therfore it looked like I owned alot of Patrols all over the US.
Keith Y. (npca-Danette&Keith)
Has thanked: 12 times
Been thanked: 36 times
Post by sleepyzzz »
Keith wrote:1962 Hard Top L60-2-00675 P18830 Berryville,AR Danette&Keith
Keith, one day we need to get together and talk Patrols. only 45 miles apart and never met you. I did work out of my Patrol one Friday over to Eureka Springs, hoping you might see me and introduce yourself, but it didn't happen. maybe one day we will meet up and run the gravel roads up the mountain and down to the Buffalo National River.
1967 SPL 1600
2013 Nissan Rogue
2001 Nissan Sentra SE R
Thanks for this info! I have made the corrections to the Registry. :D
