Speedometer Disassembly Guide
- Has thanked: 646 times
- Been thanked: 1149 times
Re: Speedometer Disassembly Guide
Duh! This one is green powered and zero emission! It's better for our environment
- Has thanked: 12 times
- Been thanked: 36 times
speedo turned out nice.
1967 SPL 1600
2013 Nissan Rogue
2001 Nissan Sentra SE R
2013 Nissan Rogue
- Has thanked: 7693 times
- Been thanked: 2476 times
Or, you could always just do this. No tampering involved.
Did you know that there's a difference in speedo's between right hand drive and left hand drive Patrols? I discovered this while installing it and had to quickly do some modifications! The tabs on the rear housing make all the difference.
- Has thanked: 800 times
- Been thanked: 1269 times
RiverPatrol wrote:Or, you could always just do this. No tampering involved.
HAH !
Now I'm not the only one around here teasing....
faux40 wrote:Did you know that there's a difference in speedo's between right hand drive and left hand drive Patrols? I discovered this while installing it and had to quickly do some modifications! The tabs on the rear housing make all the difference. John
Thanks for pointing that out John. An easy fix, no doubt.
RiverPatrol wrote:faux40 wrote:Did you know that there's a difference in speedo's between right hand drive and left hand drive Patrols? I discovered this while installing it and had to quickly do some modifications! The tabs on the rear housing make all the difference. John
Something else occurred to me. I think the location of the mounting tabs also has to do with the year of the Patrol. Starting in '69 the speedometer was installed to the right of the steering wheel, prior to that it was on the left. When the location changed, so did the position of the mounting tabs. Been there, done that.
That's funny! Did the RHD version swap the speedo to the left in '69?RiverPatrol wrote:RiverPatrol wrote:faux40 wrote:Did you know that there's a difference in speedo's between right hand drive and left hand drive Patrols? I discovered this while installing it and had to quickly do some modifications! The tabs on the rear housing make all the difference. John
- Has thanked: 529 times
- Been thanked: 301 times
The earlier speedometers have a different connection for the speedometer cable also. So you need to make sure you have the right type for your year of vehicle.....
Older style is on the left and newer is on right...
Jeff
50Car
50Car
The speedo connector change was made in '65.
