Starter, radiator an other stuff.
- Has thanked: 4 times
- Been thanked: 10 times
Looking for a starter and radiator for my patrol as mine are dead.
Also looking for an engine,trans and transfer case to have as rebuilds.
Thanks
Doc
Thanks
Doc
- Has thanked: 652 times
- Been thanked: 632 times
Re: Starter, radiator an other stuff.
I might have a starter for you. I will check it and make sure its ok. I will let you know.
- Has thanked: 7750 times
- Been thanked: 2483 times
What's up with the radiator? I have yet to see one of those fail, unless something is shot through it.
- Has thanked: 42 times
- Been thanked: 247 times
mine failedRiverPatrol wrote:What's up with the radiator? I have yet to see one of those fail, unless something is shot through it.
my local radiator bloke reckons he's seen more than one 60 Patrol radiator split the brazing between tanks and core - usually because the original 7psi cap has been replaced by a 13psi, which is more commonly available here. Apparently the shape and size of the 60 radiator means it doesn't like having nearly double the design pressure inside it...
cheers,
D
Yes, that would make sense. That's a lot of copper to be tossing out, hopefully you can recycle the old one to help pay for another one.
Actually the core itself was ok, after a good flush. Just needed to have the tanks removed, repaired and replaced - and have the correct cap fitted.RiverPatrol wrote:Yes, that would make sense. That's a lot of copper to be tossing out, hopefully you can recycle the old one to help pay for another one.
New cores are pretty steep ( AU$700-$900 fitted ) thanks to lack of competition in Australia, but at least they're available.
cheers,
D
the radiator is leaking from the rear, not sure what happened to it. My concern is the small issue becoming something catastrophic on a longer trip. If I cant find a stock one I may have a custom one made, I am just trying to deal with all the issues especially while i cant drive it anyhow.
Thanks
Doc
Thanks
Doc
