Need an exhaust flange... actually need two!
Parts for sale, or free
Has thanked: 646 times
Been thanked: 1149 times
Post by faux40 »
Howdy All,
I'm in need of a couple of exhaust collector flanges (or someone with the skill to make one from scratch?). Does anyone have one or two that they'd be willing to part with?
As you can see, this one has a slight issue...
Thanks!
Has thanked: 6017 times
Been thanked: 1601 times
Re: Need an exhaust flange... actually need two!
This one you can source at the auto parts store.
I just did a search, and found this set of (2) at Amazon
http://www.amazon.com/Remflex-2-Bolt-Un ... B00IQHLJRC
2 inch pipe, 2 bolt holes, set of 2, Heating and cooling of the exhaust system causes header and manifold flanges to warp
3 inch bolt hole spacing
Check if 3 inches is indeed the correct spacing. Price is $12.33 + shipping.
Post by faux40 »
Doh! Sorry -- The picture really makes it look like the gasket. It's the cast iron flange that slides up on the exhaust pipe and bolts to the bottom of the manifold and squishes the gasket. Here's a better picture...
Thanks!
zed
Has thanked: 203 times
Been thanked: 678 times
Post by zed »
Has anyone installed the Remflex (8014) 2" 2-Bolt Universal Exhaust Gasket 3” bolt hole spacing that Esteban referenced above?
Has thanked: 310 times
Been thanked: 176 times
Post by bosque »
I know you said you do not have the other missing piece but.....weld it?
Next I would try to mill one. Next have a casting company make a few if not too cra$y.
This is kind of a weak link part and will be needed more and more. Good luck. :think:
Post by faux40 »
Sorry - I did resolve this... on my other thread! Anyway, I cut a new one out of 1/2" plate... Then I bought a plasma cutter!
3216
3219
Keith, I have not bought that gasket, but will probably order one. Today after looking your post, I decided to do the following picture, and compared the two, and they look almost carbon copy. Based on the "on centers" dimensions for the bolts, of 3", I measured the one from Amazon, and the other dimensions are noted below.
The dimensions of the original gasket that I have, were physically measured first, and then following the same procedure as with the picture from the website. Just by the pictures alone, the one from Amazon looks better.
By the way, the Remflex says that it's 1/8" and compress half. The original one that I have is only 1/16" (maybe it's not that original after all, and could be from an aftermarket gasket set)
Post by bosque »
Esteban,
Your pic of the original looks correct and original Nissan part. I had a few of these and sold/traded them.
They had a metal version exh gasket that fits and might be better Nissan 20691-87800.
