1964 Nissan Patrol soft top frame off restoration
Has thanked: 181 times
Been thanked: 174 times
Post by RMP&O »
This is a 1964 Patrol I am restoring for a client. It is receiving a full frame off restoration. Being an early truck it has been tough to get some parts and be accurate in the resto. We have been working on this truck for three years now, of course not full time, but we are on the home stretch now.
Rather than go through the previous months and years of the build it simply seems best to pick it up where we are now. This truck has taken a long time to get to this point,many hurdles had to be tackled and overcome. Getting parts has probably slowed it down more than anything. I went into this project knowing a lot about Patrols, by the end of it I have learned a lot.
Just a little background info. This Patrol came from New Mexico, not far from the Mexico border. I purchased it from another Patroller, Danner. I started the resto many years ago but after only getting so far the project was put on hold and the Patrol put in storage. A good number of years later I had decided to sell the large majority of my Patrols and scale back to just one or two. So I sold the 64 Patrol along with a large load of parts I had been saving for many years. Shortly after the sale I was contracted by the new owner to do a restoration.
This Patrol was taken down to a bare frame. The frame was sand blasted, restored and rebuilt. The #2 cross member required extensive work and was fully fabricated. Once restored the frame was coated on the inside with Rust Bullet. All components of the chassis were cleaned, sand blasted and painted black along with the frame. New leaf springs were made by Alcan. The engine received a full rebuild. Starter and generator fully rebuilt, an NOS water pump, oil pump and fuel pump were fitted along with an NOS distributor. The trans and t-case were also fully rebuilt including new synchro rings in the trans. The axles were rebuilt including the ring & pinions. The brakes have been fully refurbished including springs, metal & rubber lines, wheel cylinders and shoes, drums were also turned down. All hardware on the truck was plated with zinc, zinc with yellow chromate and zinc with black chromate. Seats are currently being rebuilt by our upholstery shop. Before long a new soft top canvas will be made. We are using original 16" wheels, new tubes and flaps along with a set of Michelin XZL tires. The Patrol has a PTO winch.
The color for the Patrol is not an original Patrol color. This truck was white when it was sold by Nissan/Datsun in 1964. Originally Roy Rogers green was discussed for this truck. There is a lot of Patrols out there though that color and the owner wanted something different but still green. I sent the owner the following pictures and he really liked the color. Since it is not an original Patrol color I did not have the data on this color. We did find a later Nissan color though that was a close match.
The Patrol was at the body shop for most of the winter and only recently come back into my shop. I have started in on final assembly.
You may notice the leaf springs are giving a lot of lift and the rear shackle angle is not ideal. These springs are giving over 3" of lift which is to much for this build. New leaf springs are being made that will be in the max of 1" lift. I will take and use these lifted springs in my 68 Patrol. That truck I am going to run a 33" tire and will be lifted. However, I will likely remove a few leaves from the pack to lower the truck a bit.
I hope you enjoy the restoration and will follow along.
Re: 1964 Nissan Patrol soft top frame off restoration
Love the color, LOVE the tires, and the attention to detail on the project convinces me that you are certifiably insane... :twisted:
Many props... :clap:
Yeah- trying to extract a color from old, grainy marketing photos is brutal - I've put in many, many hours trying to track down the original color on my 62, because the shade of green on that truck is not 558 green like most other Patrols. As near as I can tell, my 62 is painted a shade of green that was more common on early 320 pickups/utes; so I'm going to end up having a custom color match done on it, and try to get it as close as I can... :geek:
At first, I thought the Patrol in your 2nd pic was the same one from the 64 Brochure (same front plate, etc):
I figured (guessed ;) ) that the one in this brochure picture was early Olive green (code 352, according to the Dulux sample card I found)... but the Patrol in your picture is a later truck (a 68, probably?), so who knows if they are the same color.
Regardless, your customer picked a very cool color- it looks dynamite.
Post by RMP&O »
Thanks Rob. I have all the parts books, including the last one issued in 1980. All paint colors are listed in these books. During the 70's a few colors not seen in N. America were added like orange and grey. However, the green seen in the brochures I posted is not listed anywhere in any Nissan literature. This is why I believe it is not an original Patrol color and perhaps old school photoshop which is the reason it appears in a few brochures only. The color has a lot of grey in the green. Like I say the color used is from a newer Nissan, iirc late 80's or early 90's. I do not have the info handy on the paint code or model used on but it is a Nissan color.
Nissan did a lot of random stuff on these trucks. I have seen all kinds of oddities and it doesn't seem like the trucks were very well defined until 1968. Perhaps your 62 they simply ran out of paint that day and with only one (or maybe a few) trucks left on the assembly line they borrowed some paint from 320's. Or it is possible it was a special order color. Who knows really and it will likely remain a mystery forever.
Has thanked: 104 times
Been thanked: 175 times
Post by Swerve »
Agreed the colour is great.
The newer springs sound like a better option, will be a shame to get this beast dirt, wet or even sunshine on it when complete
Post by RMP&O »
Some chromed items fitted. The outer door handles are not finalized. I am waiting on some thin rubber sheets I can make some gaskets from. The door handles have a small rubber gasket behind them. So in the picture the outer door handle is not bolted down yet, hence it not being straight.
Has thanked: 84 times
Been thanked: 327 times
Post by miller »
Ian, did you get the window winders re chromed? If so how did you reattach the handle to the winder?
Post by RMP&O »
We did not need to plate the whole window regulator assembly, they were in good condition. The window crank handles as well as door handles come off by way of a small pin. Push the round plastic trim piece inward and you can see a pin in the handle behind the the trim piece. Little piece of wire or a small punch and you can push the pin right out. Handles come right off with the pin out.
Let me know if you need a picture.
Post by RMP&O »
Un-restored vs restored
making gaskets, believe it or not, I had a bit of old stock fuel line that was about 6" long with the flare on one end. I sharpened up the other end of it with the die grinder and used it as a punch to put the holes in the new rubber gaskets. Repurposing Patrol parts rocks! 8-)
installed for good
rebuilding the door lock
Has thanked: 6021 times
The amount of work even to the smallest detail is unbelievable. Not a single bolt has been left unattended! The pictures are pure p0rn!
This Patrol is going to end up looking way better than the day it rolled out of the assembly line. :clap: :clap: :clap:
Post by miller »
RMP&O wrote: The window crank handles as well as door handles come off by way of a small pin. Push the round plastic trim piece inward and you can see a pin in the handle behind the the trim piece. Little piece of wire or a small punch and you can push the pin right out. Handles come right off with the pin out.
Great, thanks mate.
PS.. I love this picture!!!!
