Lubrication areas...
Has thanked: 202 times
Been thanked: 75 times
Post by offroadkid »
Has, or does anyone ever lubricate their starter and clutch/brake pedals? I always looked at the bearing on the starter but until I read the owners manual didn't know that you could simply push it down and drop oil in it!! It says to use motor oil.
It also shows the area to add oil to the water pump!
1966 Patrol
1997 Toyota Land Cruiser Collector Edition-built for expedition wheeling
"Some dream in color, I dream in 4 wheel drive"
Instagram: we_lexplore
facebook: https://www.facebook.com/offroadkid
Re: Lubrication areas...
I looked but don't see the grease nipple on my water pump.
1966 Patrol
Has thanked: 6018 times
Maybe the water pump was replaced at some point. The newer design pump is lubricated for life, has a totally different bearing and seal.
I've always lubricated the starter motor and also the pedals. Not as often as called for. Hey, thanks for the reminder.
The oldest Patrol with the mechanical linkage for the clutch was fitted with 26 grease zerks! Probably the most of any 4wd ever.
and I've got FOUR of them..... so over 100 zerks for me.. :lol:
I better start buying my grease by the drum.
Esteban wrote:The oldest Patrol with the mechanical linkage for the clutch was fitted with 26 grease zerks! Probably the most of any 4wd ever.
Funny you mention it! I have a '66 with a mechanical clutch and I had it up on the lift at work the other day and I thought I had got them all, until I climbed under it again today to find more that I missed by the levers to the transfer-case.
1966 Patrol
Has thanked: 7709 times
The later water pumps, after about '65, didn't have the greasable bearing. So, there was no grease fitting for it.
RiverPatrol wrote:The later water pumps, after about '65, didn't have the greasable bearing. So, there was no grease fitting for it.
Perfect, thanks! For some reason this thread doesn't give me the option to "thumbs-up" thank you!
1966 Patrol
Has thanked: 646 times
Been thanked: 1149 times
Post by faux40 »
offroadkid wrote:For some reason this thread doesn't give me the option to "thumbs-up" thank you!
I've noticed this too -- Does anybody know why this is?
This is the first time I have seen this. It's only missing on my post, still there on everyone else's. Hmmm... :think:
Post by faux40 »
It happens regularly -- I probably see it every couple weeks or so.
