Rolly's 76 Soft top
Re: Rolly's 76 Soft top
Looking great Rolly- !
Someday I wanna hear a sound/video clip of that big V8 doing its thing... ;)
Has thanked: 17 times
Been thanked: 50 times
Post by Rolly »
moore_rb wrote:Looking great Rolly- !
Me too!! That can be a job for today actually. Just need to connect the wiring back up, put in new fuses, sacrifice something to the Nissan gods (here puss puss), cross my fingers and hit the ignition. Wish me luck.
Topless is the only way to go
Post by Rolly »
miller wrote:Mate she's coming along. I just re read your thread from the start. Great progress!
Thanks Miller, this little community helps a lot. When I'm lacking in motivation I login and check out other people's projects until I feel the urge to start tinkering again.
Post by Rolly »
Success!! After about a year of sitting she fired up first go. Tried to upload a video of her running but no luck (sorry Moore) she sounds purty though.
And yes the cat survived.
Has thanked: 7716 times
Upload the video to YouTube, then link to it here.
Post by Rolly »
Had another of my awesome ideas :D . I don't want the whole thing to be white so I'll be painting various bits a different colour ie; the grills, the windscreen hinges, the air louvers' beneath the windscreen, the glove box and speedo panel etc. Thinking something like a metallic purple or the like. Anyway, seeing as I don't have the floor matting I'm thinking of fitting out the entire foot wells with nice shiny checker-plate and then painting the transmission tunnel the metallic colour I decide upon. Make a nice contrast I reckon and be one of a kind.
Has thanked: 33 times
Been thanked: 35 times
Post by 250g60 »
Hi Rolly, your G60 looks like its coming along really well, the colour idea sounds good to break up the white
Has thanked: 104 times
Been thanked: 175 times
Post by Swerve »
Rolly,
Looking great mate.
Re FG panels, I have new front grill, guards, bonnet, windscreen etc. They all came with out mounting holes.
I reckon if you can dummy fit all panels using clamps etc. Then mark out hole positions etc. Might need to use a steel grill to help get hole alignment right on guards, then swap out once guards drilled etc.
Either way I'm sure you have it sussed so keep going.
thinking
if you clamp the left steel guard to the right FG guard (the firewall edge). You can transpose the mounting holes :) then swap and do the other side
Post by Rolly »
Swerve wrote:Rolly,
thinking
Good thinking! I've already got one guard on, just needs a little adjustment. I'll try that with the other side (as long as there are holes, the rhs was rusted out), think it was held on with glue and by way of being bolted to the inner guards and rad surround :shock: . I'll put some pics up.
Post by Rolly »
So then, first attempt at fitting a fibreglass guard. I got close, a little adjustment and she'll be right. I'll use your suggestion for the other side Swerve, should work better.
