Front brake cylinder rebuild?
- Has thanked: 49 times
- Been thanked: 141 times
I know you can buy replacement front brake cylinders on ebay.
However, has anyone tracked down a compatible rebuild kit, instead of buying them new?
- Has thanked: 6017 times
Re: Front brake cylinder rebuild?
You can get the cup as a spare. When Nissan sold repair kits for the brakes, they only included the cup and the dust seal. Hope you seal is good.
The compatible parts list the following # 44112-E5010
Some of the Nissan parts online places list them. I hope they have them. I will try to find the Tokiko part number for the cup.
All the cups for front and rear cylinders are the same. 1"-diameter.
- Has thanked: 800 times
- Been thanked: 1269 times
The question I have is: can the cylinders be sleeved...?
I tried to wet-hone a couple of my original Nabco front cylinders, and I still could not get the new cups to seal up against the bore - they just kept losing pressure when the truck would sit for a while.
I would LOVE to find a stainless sleeve that fits, or find someone with better brake cylinder rebuilding skills than I posses - I have about 12 original Nabco cylinders that I think could be rebuilt....
- Has thanked: 97 times
- Been thanked: 568 times
Doesn't that place that sleeves Master Cylinders also do Brake Cylinders?
- Has thanked: 7706 times
- Been thanked: 2480 times
I thought Then and Now would resleeve them. If not the, there was another place. I recall that it was pretty pricey though.
The other place is White Post Restorations.
http://www.whitepost.com/brake.html
They are about 30 min from my office. They don't list the prices, and you have to call for them: (540) 837-1140
- Has thanked: 173 times
- Been thanked: 306 times
I recently had the Brake Master Cylinder rebuilt. Mine was a single reservoir and all replacements I found were duel.
The master cylinder was re-sleeved in stainless steel ($100), new cup etc ($50) - the kit seemed readily available and labour $50. The all up cost was $200.
I enquired about getting the slave cylinders re-sleeved. Basically the cost was the same as the MC. So for the front brakes a total of $800. I picked up a new set on ebay (4WD Products) for $138 delivered. Ordered one day delivered the next.
Not sure if I will get there.
Not sure if I will get back.
But I usually do!!!
But I usually do!!!
I ended up going this route as well. Total cost for the slave cylinders and to ship to the US was $164 USD. They arrived very quickly for an international ebay purchase - around 4 days to my door.Peter60 wrote:I picked up a new set on ebay (4WD Products) for $138 delivered. Ordered one day delivered the next.
