List the change
- Has thanked: 181 times
- Been thanked: 174 times
Re: List the change
Speedo, change in 66. Connection for cable is different and not comparable. Same thing for the cable, change made in 66. Listed in some parts books as a change made in 63.
- Has thanked: 257 times
- Been thanked: 270 times
Re: List the change
My 68ish instrument cluster has actual numerical PSI, degrees F, and amps markings.
My doner 69 only has generic HI, LO, etc. range markings.
- Has thanked: 800 times
- Been thanked: 1269 times
Re: List the change
Side vent doors -
Pre- 68 Flat:
68-later- recessed center:
Pre- 68 Flat:
Re: List the change
Oil pressure sending unit.
Early P engines it is a different thread size on the sending unit as well as a different unit all together. Wire connection is also different. This means the hole tapped in the block for the sending unit is also different from early to late P engines.
- Has thanked: 202 times
- Been thanked: 75 times
Re: List the change
My L60-06990 has a PTO hole in the rear bumper but no PTO installed, also it has a full size gas tank!moore_rb wrote:I have 4 frames:RMP&O wrote: One more oddity, I have a 64 here without the hole in the back bumper for rear PTO output. I also have a 67 here without this hole. All other Patrols I have ever seen up to 68 have this hole.
serial number (L60-2-00504- VIN plate confirms 1962 model year) - No rear PTO hole
serial number (L60-3-00617- VIN plate confirms 1965 model year) - No rear PTO hole
serial number (4-L60-02565- no VIN plate, so model year unknown) - rear PTO hole is present
serial number (L60-00511- VIN plate confirms 1966 model year) - rear PTO hole is present
Here is my (unsubstantiated) theory - The serial number stamped on the Patrol's frame does not have any association with the model year of the finished truck (the year stamped on the VIN plate) - Instead, I think the serial number stamped on the frame indicated either the year, or the manufacturing sequence, during which the frame was fabricated.
There is only one model year where there is a definite correlation between the two numbers - and that is 1962- All 62's in the registry have a "model year" on the VIN plate of 1962, and a frame serial number that begins with "L60-2". Now, we can guess that "L60" indicates the SWB frame model (Esteban's 65 demonstrates that "LG60" indicates the early MWB frame design) - and we can speculate that the "-2-" might indicate the year that the frame was fabricated (but there is no information I have found to prove this- it merely fits a pattern)
Following the "L60-2-xxxxx" serial number sequence, it seams the frame serial numbers started following a pattern that does not necessarily align with the truck's VIN plate model years at all:
A) "L60-3-xxxxx" serial numbers came after "L60-2-xxxxx" (the "3" either designates a run of frames welded up in 63, or it designates the "3rd" manufacturing run of frames)
I'm willing to bet a 6-pack of beer that any US Patrol frame out there that starts with either of these number sequences ("L60-2" or "L60-3") does not have a rear PTO hole) - these frames ended up underneath trucks from the 1963 model year, all the way up and into the 1965 model year (like my white Patrol listed above in blue)
B) After the "L60-3-xxxxx" frame series, Nissan changed the frame stamping format to "4-L60-xxxx" (there are also 2 examples of "4L60" in the registry, but I'd bet that the dash is there between the "4" and the "L60" on those truck's frames, and was merely lost in translation when they were added into the registry.)...
Again, it is reasonable to suspect that the "4" indicates frames that were assembled during 1964, or it might also just indicate the 4th frame manufacturing sequence.
You will find "4-L60-xxxxx" (or "4L60-xxxxx") stamped frames underneath Patrols that are either 1964 model year, or 1965 model year; and I would be willing to bet another 6-pack of beer (we're up to two 6-packs now) That this "4th" frame manufacturing sequence is when the rear PTO hole first appeared...
C) After the "4th" production run of frames, (or, after the 1964 frame assembly run, whatever that "4" represented), Nissan dropped this single digit sequential indicator from the frame numbers altogether, and simply started stamping all frames "L60-xxxxx" - You will find frames with this "L60-xxxxx" number format underneath the vast majority of US market Patrols, from 1965, right up to 1969.
I'm NOT willing to wager any beer on whether every Patrol frame stamped with a "L60-xxxxx" style number originally did, or did not have a rear frame hole from the factory... Some trucks with "L60-xxxxx" serial numbers on the frame do have the rear hole, and others do not... Were these frames manufactured specifically with (or without) the hole based on options? Possibly- One option I considered was that if a frame with a "L60-xxxx" number on it does have the rear PTO hole, then perhaps the frame was originally provisioned for an early-style "short" fuel tank, while some frames with "L60-xxxx" numbers that were assembled to use the "wide" style tanks did not include the PTO hole (since there was no use for it, due to it being blocked by the fuel tank).
Or, were the rear frame cross members on these "L60-xxxx" trucks repaired or replaced at some point in the past, using cross members from older trucks...? Beats meany of these scenarios seem feasible, but I think the possibility that the rear PTO hole might have originally correlated to the width of the fuel tank on these "L60-xxxxx" frames seems plausible.
So, that's my theory: The existence of a rear PTO hole has no correlation whatsoever to the model year of the Patrol ... the rear PTO hole is correlated only to the specific production run stamped on the frames, and the frame numbers do not reliably indicate the model year of the truck, either; they only indicate the year that the frame was built (or during which manufacturing sequence the frame was built)...
1) Frames stamped with "L60-2-xxxxx" - No rear PTO hole
2) Frames stamped with "L60-3-xxxxx" - No rear PTO hole
3) Frames stamped with "4-L60-xxxxx or "4L60-xxxxx" - Yes, rear PTO hole
4) Frames stamped with "L60-xxxxx" - No clear correlation between this frame number format, and the existence (or lack) of a rear frame PTO hole, although it seems that the presence of the rear PTO hole might correlate to whether the frame was originally welded up with provisions to use a "short" fuel tank (PTO hole="yes") , or to use a "wide" fuel tank (PTO hole= "no").
Footnote: Some of the 69's used frames that also have a "K" prefix (KL60-xxxxx) on them, which seems to have appeared right about the same time in mid-68 that Nissan decided to drop the Soft top option, meaning all US market SWB Patrols (and frames) were going to end up beneath hard top trucks only; and it also seems that Nissan decided to use the rear hole for reverse light placement when they began offering Patrols with reverse lights...
So, there are two 6-packs of beer out there for anyone who can prove me wrong on either of those two earlier points - BUT, in order to claim your free beer (which will actually be a paypal transfer of whatever the price of a 6-pack of your favorite beer is, since I'm not offering to pay beer shipping) you have to provide FULL pictorial evidence of the truck's VIN plate, the frame number stamping, and the existence (or lack) of a rear PTO hole, as well as signed, notarized statement of verification that your frame has never been patched using the rear piece from another frame, or subjected to any other such frame-butchery during it's entire lifetime.
If your name is Esteban, 2869ral, or Mr. Toad, then I will give you the full benefit of the doubt about your frame's originality, since your trucks' origins can be traced back decades earlier than anyone else's around here (but, I've already verified that the frames underneath the Patrols belonging to the 3 of you do match the patterns I outlined above, so NO free beer for you....![]()
1966 Patrol
1997 Toyota Land Cruiser Collector Edition-built for expedition wheeling
"Some dream in color, I dream in 4 wheel drive"
Instagram: we_lexplore
facebook: https://www.facebook.com/offroadkid
Re: List the change
Oil filter housing, early up to 65ish had no check valve, post-65ish does. No check valve means oil drains back into sump on shut down.
firewall front (engine bay) body mounts, the reinforcement changed. Early has a flat piece of steel to reinforce it, mid has a funky corrugated reinforcement and by 68 the whole design changed. The corrugated one looks like Nissn used apiece of roofing material.
Re: List the change
Windshield vent interior screens: Not present in any pre-66 Model year literature, so probably not original equipment on pre-66 Patrols. (Edit: I am probably wrong about this- read more below)
Front transmission hump floor mat: Pre-68 has 2 large snaps (located at 11:00 and 1:00) , and 68-later floor mats have a single, smaller snap at 12:00 position.
Tail lights and front marker lights: Up until 1967 used 2-1/2 inch Everwing lamp assemblies with glass lenses, 1968 (US) and 68-newer (international) used 2-1/2 inch Koito lamp assemblies with 2-screw plastic lenses. 1969 (US) used large 3-1/2 inch Koito round taillights, and large, rectangular Koito front marker lamps.
- Has thanked: 6021 times
Re: List the change
Mine is a 65 from overseas, and came with the vent screens. But I guess that a 65 made vehicle was sold as a 66 sometimes, so the above applies.moore_rb wrote:Windshield vent interior screens: Not present in any pre-66 Model year literature, so probably not original equipment on pre-66 Patrols.
I remember seeing later 70s models, without the screens, but don't remember the year.
Re: List the change
Thanks Esteban - I Agree that nothing on these vehicles seems to be set in stone, and there are differences between US Patrols and International market Patrols.
Here is how I formed the basis of my earlier opinion about the cowl vent screens:
The following three brochures all mention the "cowl ventilators" as standard features, but none of these brochures indicate that the internal screens are present (neither the text, nor the pictures indicate that the screens are available as standard, or as optional ):
But, this following brochure is the earliest one I found that does show the interior vent screens in the photos, and it is also the earliest one I found that showed the later-style side doors, and door hardware, as well as the first brochure that shows the 2-piece 15 inch wheels as the standard wheel :
Interestingly- Leslie's 1966 Togo is 100% adherent to the features and images in this 66 brochure with the light blue Patrol on the cover; while my 66 from El Paso is 100% adherent to the "earlier style" features and images from the 66 brochure above that has the darker blue, topless Patrol on the cover; and come to think of it, that Patrol has the vent screens, as well (similar to yours)...
So, this led me to believe that the internal vent screens came along in 1966, the same time that the side doors and wheels were updated, but your 65, and my "early" 66, which both have the screens, along with the earlier recessed door hardware, suggests that maybe my observations were not 100% correct.
At any rate- the primary reason I was researching these screens in the first place was because neither my green 62 softie, nor my white 65 hardtop have the vent screens, but my red 65 does have the vent screens (similar to your 65) - I did not know if the screens on the red Patrol were original, or if they were added later on...
of course, my white 65 indicates (by the serial number) that it was actually built in 1963, so that would probably be why the vent screens are not there.
So, maybe Nissan began putting the screens on during 1965, but did not publish the new brochures to reflect the screens until 1966...?
Re: List the change
The discussion re-raises another earlier point-
Most of these features and options align themselves to the Patrol serial number more often than they line up to the model year - Which lends more credibility to my earlier suspicion that the model year stamped on the VIN plate only reflects the year that the Patrol was either A) exported, B) sold, or C) titled for the first time; and the year stamped on the VIN plate has no bearing (at all) on the year that the Patrol was actually manufactured (at least for US Patrols, this seems to be the case).
