G60 Build South Africa
- Has thanked: 7696 times
- Been thanked: 2477 times
- Has thanked: 3 times
- Been thanked: 43 times
Re: G60 Build South Africa
Made up my own front prop shaft. Long story the prop shaft manufactures in our area do not have tubing with an id of 39mm nor new UJ ends
to match the Patrols pcd. I turned sleeves on the lathe and made use of 75mm tubing. Also manufactured a adapter between the Cruiser box and Patrol prop shaft. A run out of only 0.01 mm over 750mm not to bad.
Took the baby for a test drive yesterday, all I can say I am impressed very impressed.
- Has thanked: 800 times
- Been thanked: 1269 times
That's awesome...
- Been thanked: 136 times
Great looking Patrol. I really like that you didn't radius the rear quarters. I'm weird that way?
- Has thanked: 6011 times
- Been thanked: 1600 times
Excellent work with the prop shaft! Your fabrication skills are endless!!
ratpatrol66 wrote:Great looking Patrol. I really like that you didn't radius the rear quarters. I'm weird that way?
Esteban wrote:Excellent work with the prop shaft! Your fabrication skills are endless!!![]()
Thanks guys only helping the kids with this one. Need to get it finished before end September, big 4x4 get together in October.moore_rb wrote:That's awesome...
- Has thanked: 84 times
- Been thanked: 327 times
Great work on the prop shaft. Roll cage looks great too.
Progress a little slow. Body works almost done.
