Front Wheel Cylinder Kit
BJA
Has thanked: 13 times
Been thanked: 23 times
Post by BJA »
In need of four (4) front wheel cylinder rebuild kits for a new project..... know these are hard to come by but hoping someone had some laying around. Thank you in advance.
Has thanked: 7727 times
Re: Front Wheel Cylinder Kit
The wheel cylinders are cheap enough on eBay, it's hardly worth the effort to rebuild them. Here's the link: http://www.ebay.com/itm/261419018581?_t ... EBIDX%3AIT
Has thanked: 173 times
Been thanked: 306 times
Post by Peter60 »
I can recommend them. I ordered a set one day and they were delivered the next day. I live in Australia, so not sure about delivery to the US, but I assume they would be fairly quick.
Not sure if I will get there.
Not sure if I will get back.
But I usually do!!!
Been thanked: 3 times
Post by Kardok0 »
I ordered a set for the front, shipped on 9/27 received them on 9/30 ... I was amazed by the express service !!
Has thanked: 85 times
Been thanked: 97 times
Post by ShowMePatrol »
Are they available for my 63 model?
Has thanked: 6023 times
Been thanked: 1605 times
They will fit. You'll have to double check the thread fitting, since Nissan changed to metric around 78. Not sure if the wheel cylinders were changed.
Post by Kardok0 »
I believe NAPA can match the wheel cylinder but it's going to be metric, then you have to change all the junction blocks and master cylinder to fit the other end of the brake steel line , it's a chain reaction !! It's cheaper to buy them from down under ! Take RiverPatrol's advice, you'll be happy... I did .
