Factory winch on a 65
Original and compatible parts
Has thanked: 1 time
Been thanked: 51 times
I recently got a 65 patrol. It has what I was told was a original factory installed pto winch . The winch is a Tulsa winch. I'm curious if what I was told was correct or if it was an after market
Has thanked: 7709 times
Re: Factory winch on a 65
The "factory" winches were actually installed at the dealer. In the US, the original winch used was a Koenig. I don't think there were any markings on the PTO gear box to indicate the manufacturer.
Has thanked: 1 time
does anyone have a picture of the factory supplied pto unit? i cant tell what mine is as i see not markings? mine is leaking like crazy from the cylinder sleave does anyone know if parts are available for a rebuild? also can i just undo the bolts and pull the pto assembly off to work on it or do i have to pull the whole transfer case and dissassemble it
Been thanked: 1989 times
Post by L60Boerne »
Matt, Like RiverPatrol said they were aftermarket items installed by the dealer. My 63 has a PTO winch from that era. I will take some better pictures if you need them in a few days. I'm not sure what brand it is as it stays in a clandestine garage about 20 miles away while it is recovering from 50 years of wear and tear.
Regards,
L60 Boerne
Has thanked: 1 time
Oh ok I misunderstood. I thought the Pro drive assembly was nissan but the shafts and winches themselves were dealer options
Has thanked: 514 times
Been thanked: 631 times
Post by rdarnell »
I was thinking the actual PTO is from Nissan? They show it in the parts catalog and I think I have seen it in the service manual also.
That is the theory, that the PTO is Nissan. There aren't any stampings on it to identify it. There is no evidence to show that it was an aftermarket item though, like the winch.
