Parting two 67's
Parts for sale, or free
Has thanked: 7711 times
Re: Parting two 67's
The transition from plaque to decal happened in '67.
Gosh, there are thousands of pictures in the Gallery. Take your pick.
Has thanked: 181 times
Been thanked: 174 times
Post by RMP&O »
soft60 wrote:How were these originally attached?
There is another one up right now - $40 or make an offer.
They were attached with brass "hammer" rivets. Hammer meaning a rivet not installed with a rivet gun but with a hammer or punch.
Post by RMP&O »
Alright folks, I have a good handful of parts pulled, cleaned, inspected and ready to ship. Here is the deal with my pricing; it includes shipping, is based upon how rare a part is, how good of condition a part is and how much it will cost me to ship the part. Since I am including shipping in my prices that also includes packaging, some items take a lot more effort to package and make sure they are safe for the journey to you from me. Obviously weight and size also plays into shipping expenses. I can ship UPS ground or US Post, your choice. Prices only include shipping in the lower 48, anywhere else and shipping will be more. Parts are cleaned in my parts washer and thoroughly inspected by me, where appropriate the parts have been tested. Original mounting hardware is included when available. I will hold your part for a couple weeks once you request the item, if you don't respond I will list the part(s) you have requested as available. Please private message me once you have viewed your part(s) and we can arrange payment and shipping. I take paypal, personal check, money order or cash.
r1lark: ash tray: $45, hand crank $85 = $110 total
Weasel451: LHS window regulator: $60, window crank handle $25 (no pics yet, pending pull, can't supply good trim with it), washer inside oil filter $10 (pending pull), RHS front seat assembly $250 = $345 total
Post by RMP&O »
2869ral: Wiper arms, excellent set is $85 and soso set is $45, both = $130
excellent set
soso set
ShowMePatrol: Master cylinder $100, passenger inner door handle (is your truck a 66 or 67? Do you just need the handle?), pre-69 steering wheel (pending pull, it is on the other 67 that is still outside), fuel pump $150, generator $150 (has modified pulley) or $175 (all original) depending on which one and + $50 for mounting hardware - both test good, carb (I only have Rochesters), glass fuel filter bowl assembly $125, water protect distributor with base and drive gear $350 = current total $925
$150 generator, pulley has been modified but could be taken back to original
$175 generator, all original
Generator mount and adjuster
Glass bowl fuel filter assembly
55,000 mile working water protect distributor
Post by RMP&O »
Pdub: red/green dash lights $30 for the set, x3 split wheels (pending pull/inspection)
tnPatroller: interior glass dome light assembly $65, wiring needs a little bit of work
JWgreen: door window handle (do you just need the crank handle?), battery box cover $25 has some dents, knobs for windshield vents x3 $15 (all cracked, no pics yet), heater intake in engine bay $50 (forgot to take pic, pics coming) = $90 current total before window handle
Post by RMP&O »
Nobody has claimed these yet, original seat belt set. One of the latches is seized up from corrosion and needs some work to free it up. Some rust/corrosion on the outside mounts. All mounting hardware is included. These can be restored if you are motivated, very rare and hard as hell to come by.
$125 shipped for the set.
Post by RMP&O »
Here is what I have got to pull still, clean, take pictures of and price....
Timoun: front leaf pack and front driveline assembly
RonB: All cooling system parts
ckhorne: clutch cover
Urban60: doors (I will take pics and you can decide if they are to rough for you), LHS window reg. (pending sale), rear doors
Marshall: mirrors (pending pull), green/red dash lights (only have green), master cylinder (have another one on the other 67, the one pictured is pending sale), door stops (I have one old one but can get you a new set from Colombia), glove box handle $20, hood emblem $40, fuel cap (pending pull from other 67), dash map light $85 for assembly with glass lens and switch + all wiring (pending pics), Toshiba headlights $350 for the set with buckets included (one is pulled and tested and works, the other is on the 67 outside and needs to be pulled & tested), interior dome light assembly (pending sale), x4 split wheels (pending pull & inspection)
Pics of parts requested that are pulled and ready to ship
Here is one of the Toshiba headlights, working! :)
PM's sent if you have requested parts.
Has thanked: 69 times
Been thanked: 84 times
Post by Urban60 »
Hey! not necessary to take pictures, I will pass on the parts thanks for looking though.
Audrey
Has thanked: 97 times
Been thanked: 568 times
Post by jwgreen »
Ian,
I need the window crank handle but as discussed earlier if they are not the same as the 69 handles then I will pass on it for now. Also just want to make sure that the battery box cover is the same on my 69'?? If so I will take the battery box cover and heater intake. I have acquired a vent knob already. Thanks for all your help.
Post by RMP&O »
No worries, like I say they are not very good doors and I may need the RHS for a project.
jwgreen wrote:
Ian,
Neither door handles or window crank handles match a 69. 68+ are different, I may be able to get new ones out of Colombia though. Knobs I have are not very good anyways, I will check and see if I can verify on battery box cover. I changed my mind, the battery box cover is FREE! I noticed it is missing the tabs on one side and as you can see it has a bit of a dent on one corner. A body shop can fix it up but due to the issues, it is free.
