Oil Pan Gasket only needed 1967
Original and compatible parts
Has thanked: 18 times
Been thanked: 14 times
Post by ctcruiser »
Does anybody know where i can get just the gasket?
Has thanked: 529 times
Been thanked: 301 times
Re: Oil Pan Gasket only needed 1967
Post by 50car »
Try motorpower inc. They might have single gaskets for sale.
Jeff
50Car
Has thanked: 7716 times
You might also try seller schluderm on eBay. He sells individual gaskets sometimes.
Or, you could do what Esteban does and just use silicon sealer. :D
Post by ctcruiser »
I have called Motor Power Inc. and they do not supply gaskets and they suggested calling forklift repair companies which i tried and they only sell complete gaskets which are $200 and up.
Has thanked: 173 times
Been thanked: 306 times
Post by Peter60 »
Full gasket set is available on ebay for $91US.
Seehttp://www.ebay.com/itm/Full-Engine-Gas ... jz&vxp=mtr
It's from Australia. Looks like free shipping to US.
I have no experience with the seller.
Not sure if I will get there.
Not sure if I will get back.
But I usually do!!!
Has thanked: 646 times
Been thanked: 1149 times
Post by faux40 »
RiverPatrol wrote:You might also try seller schluderm on eBay. He sells individual gaskets sometimes.
I know that many modern cars simply use silicone for the pan gasket... most don't leak either! I'm just not sure how tight to secure the bolts without a gasket... The same torque as with a gasket?
Of course, rolls of gasket material are pretty cheap. Some raw material and a little quality time with an exacto knife and voilà! The perfect oil pan gasket.
Something like this would probably work fine - http://www.amazon.com/Fel-Pro-3019-Gask ... B000CNGY5U
Post by Peter60 »
Try https://www.amayama.com/en/search?curre ... 1121-85060
$6 US plus postage.
That part number is for my 68 G60.
I haven't used this site yet but just about to buy some "D" bushes, but others in the 60Patrol forum have.
But I usually do!!!
faux40 wrote: I'm just not sure how tight to secure the bolts without a gasket... The same torque as with a gasket?
If you want to seal the oil pan (or timing cover, or side cover, or valve cover) using pure silicone, then the best technique I've found is to put a generous bead of silicone around the oil pan (looping it around each bolt hole) then do one of the following:
1) If the engine is on a stand, then invert it so the oil pan is on top, and place the pan on the engine. Feed the bolts through their holes, and give each bolt 1/2 to 1 full turn.... then walk away from it for 24 hours. Come back the next day, and gradually snug the bolts down (10-15 ft/lbs max- or, "finger tight" plus 1/2 turn)
2) if the engine is in the truck, then after applying the silicone, place the pan beneath the engine, and set the 4 corner bolts- Again, give them each 1/2 - 1 full turn. then go around and set the rest of the bolts the same way. After all the bolts are in place, go back and slowly twist in the 4 corner bolts, just until there is no air gap between the silicone and the engine sealing flange (don't tighten them- just get them to the point that the silicone fills the entire gap between the pan and the engine). Then, once again - go do something else for 24 hours. Come back the next day, and gradually snug all the bolts down (again - 10-15 ft/lbs max)
This technique, performed correctly, can actually seal better, and last longer, than cork gaskets ... 8-)
Has thanked: 1 time
Been thanked: 51 times
This reply may be quite late However I was able to order a pan gasket from liftway in brantford canada for 20 bucks
