Oil Pan Gasket only needed 1967
- Has thanked: 529 times
- Been thanked: 301 times
Re: Oil Pan Gasket only needed 1967
Try motorpower inc. They might have single gaskets for sale.
Jeff
50Car
50Car
- Has thanked: 7707 times
- Been thanked: 2480 times
You might also try seller schluderm on eBay. He sells individual gaskets sometimes.
Or, you could do what Esteban does and just use silicon sealer.
- Has thanked: 18 times
- Been thanked: 14 times
I have called Motor Power Inc. and they do not supply gaskets and they suggested calling forklift repair companies which i tried and they only sell complete gaskets which are $200 and up.
- Has thanked: 173 times
- Been thanked: 306 times
Full gasket set is available on ebay for $91US.
Seehttp://www.ebay.com/itm/Full-Engine-Gas ... jz&vxp=mtr
It's from Australia. Looks like free shipping to US.
I have no experience with the seller.
Not sure if I will get there.
Not sure if I will get back.
But I usually do!!!
But I usually do!!!
- Has thanked: 646 times
- Been thanked: 1149 times
I know that many modern cars simply use silicone for the pan gasket... most don't leak either! I'm just not sure how tight to secure the bolts without a gasket... The same torque as with a gasket?RiverPatrol wrote:You might also try seller schluderm on eBay. He sells individual gaskets sometimes.
Of course, rolls of gasket material are pretty cheap. Some raw material and a little quality time with an exacto knife and voilà! The perfect oil pan gasket.
Something like this would probably work fine - http://www.amazon.com/Fel-Pro-3019-Gask ... B000CNGY5U
Try https://www.amayama.com/en/search?curre ... 1121-85060
$6 US plus postage.
That part number is for my 68 G60.
I haven't used this site yet but just about to buy some "D" bushes, but others in the 60Patrol forum have.
$6 US plus postage.
But I usually do!!!
But I usually do!!!
- Has thanked: 800 times
- Been thanked: 1269 times
If you want to seal the oil pan (or timing cover, or side cover, or valve cover) using pure silicone, then the best technique I've found is to put a generous bead of silicone around the oil pan (looping it around each bolt hole) then do one of the following:faux40 wrote: I'm just not sure how tight to secure the bolts without a gasket... The same torque as with a gasket?
1) If the engine is on a stand, then invert it so the oil pan is on top, and place the pan on the engine. Feed the bolts through their holes, and give each bolt 1/2 to 1 full turn.... then walk away from it for 24 hours. Come back the next day, and gradually snug the bolts down (10-15 ft/lbs max- or, "finger tight" plus 1/2 turn)
2) if the engine is in the truck, then after applying the silicone, place the pan beneath the engine, and set the 4 corner bolts- Again, give them each 1/2 - 1 full turn. then go around and set the rest of the bolts the same way. After all the bolts are in place, go back and slowly twist in the 4 corner bolts, just until there is no air gap between the silicone and the engine sealing flange (don't tighten them- just get them to the point that the silicone fills the entire gap between the pan and the engine). Then, once again - go do something else for 24 hours. Come back the next day, and gradually snug all the bolts down (again - 10-15 ft/lbs max)
This technique, performed correctly, can actually seal better, and last longer, than cork gaskets ...
- Has thanked: 1 time
- Been thanked: 51 times
This reply may be quite late However I was able to order a pan gasket from liftway in brantford canada for 20 bucks
