Hello.
zed
Has thanked: 203 times
Been thanked: 678 times
Re: Hello.
Post by zed »
Brad,
It was nice of you to let your father run the maiden drive :clap:
Has thanked: 7706 times
Been thanked: 2480 times
Re: Hello.
Cool! Another Patrol lives again. :banana-wrench:
Been thanked: 136 times
Re: Hello.
Post by ratpatrol66 »
Sounds like you were missing the muffler on the maiden drive. I like it, kind of rowdy!
Has thanked: 84 times
Been thanked: 327 times
Re: Hello.
Post by miller »
Looks like you're off to a great start. Welcome!
BJA
Has thanked: 13 times
Been thanked: 23 times
Re: Hello.
Post by BJA »
New project....purchased these two '66 Patrols from a guy in Texas that said he had had them for some time but was in need of cleaning out his garage and picked them up for a good deal. Purchased sight unseen and had them delivered to Oklahoma. The tan/rockcrawler has powertrain but the engine did not run and the white cleaner body was missing engine and transmission.
My goal/plan was to get the engine running and then pull it and the trans and gear box and install in the cleaner white body.
White Body:
Crawler:
After new distributor, fuel pump and carb work I was able to get the engine up and running again in the crawler. However when it came time to pull and install in the white body I realized the rear gear/engine mounts have been ground off the frame and possible modified for another engine altogether? I am not versed in fabrication/welding but I am sure I can enlist the proper help if need be. My other thought was to just swap the white body onto the crawler frame....Any thoughts are greatly welcome.
Re: Hello.
I added these to the Registry. :handgestures-thumbupright:
Re: Hello.
Ugh.. yeah, look at that - the frame on the white one has been butchered- even the front mounts are hacked-
Looks like someone was beginning a V8 swap, when they realized what a bad idea it was and had second thoughts.... :ugeek:
If the frame under the tan one is still structurally solid (no rust-throughs anywhere) then swapping bodies and axles should be a snap (just add time, and effort).... 8-)
