Assorted 68/69 Parts
Has thanked: 97 times
Been thanked: 568 times
Re: Assorted 68/69 Parts
Post by jwgreen »
Timoun wrote:I have a black Bakelite knob with a white "H" on it that came off my '65. If it's the one you need you can have it for the postage... though I would appreciate any help you could give me in locating a front leaf spring. :)
I would purchase the H knob off of you if you are still willing to let it go. I had my wife look at the set of springs that I still have as per her description I believe they are the rear springs. My front springs were flat as hell so I think I threw them out when I removed them.
Has thanked: 56 times
Been thanked: 39 times
Post by Timoun »
You can have the knob for the postage (I sent you a PM). Thank you for checking on the springs.
Has thanked: 43 times
Been thanked: 32 times
Post by mtnPatrol »
Updated my list of needs. I'm getting close.
Post by mtnPatrol »
Added a rear view mirror to my list. I thought it would be an easy replacement but apparently not. There also is no replacement part listed in the db. Is the oem the only one which bolts in?
Has thanked: 7744 times
Post by mtnPatrol »
Hmmm... if I remember correctly my bolt pattern is different. I think my mount is taller and skinnier with the two lower screws much closer together and further from the single screw on top. I will check it out tomorrow and post a picture.
Post by mtnPatrol »
It doesn't look as though the mirror linked above would match up. Were there multiple mirrors for Patrols? I only see one part number, 96321-c0100.
Here is where my mirror mounts:
And here is the piece it apparently mounts to:
Ok. The mirror you need has a clip that clips into the bracket. Maybe someone from Australia can come up with one for you. Or you might find one in Colombia.
Has thanked: 257 times
Been thanked: 270 times
Post by Flaggoni »
I just received today a used mirror from an individual on EBay.
I searched "ever wing mirror" It was about $7. I could see that it
snapped in like yours does. The arm that snaps in is not the correct
angle for the patrol, but I only needed the actual mirror head. I have an extra
Patrol-correct arm you could have for free if you can find another mirror head.
The head is clamped to a ball on the arm.
Mild Bill
Post by mtnPatrol »
Thanks Bill. I will look around and get back to you.
Just to make sure that I have it right. The arm snaps into the bracket and the mirror snaps onto a ball on the arm?
There are no known mirrors that bolt up to the bracket's existing bolt pattern?
