Windshield Hinges???
Been thanked: 13 times
Post by Natron037 »
Are there any sources for hinges? both of mine were broken off. Not sure if someone had found a NOS source or hinges from something else that worked. I can fix mine, but thought I'd ask too. I am having windshield glass cut locally for $175. I had asked if they would keep the pattern in case other members needed glass. Unfortunately they will not ship glass. I had also sourced windshield weatherstrip rubber #AS-1179. It is generic rubber but very close to what was in my truck. It is however the style without the internal locking strip. I.E. it has a separate locking strip that must be inserted. Just some info.. not necessarily good info, but info none the less.
Nathan
66 Patrol with odd doors
Has thanked: 7743 times
Re: Windshield Hinges???
I've seen some very creative replacement hinges before. Nothing that I could recommend though. Your best bet is to see if another member here has a set you can get. Put a post in the Wanted section, see what turns up.
