Boredom got to me
Has thanked: 11 times
Been thanked: 22 times
Boredom got to me
Post by pissan »
It was too cheap to pass up. It has a big local history and was well loved once. All the history of the car has been documented in the book, which was in the glovebox. So, I will continue to bore people, because it's rare to get a car of this age with this much info. Such as,
First oil filter change..............3000kms
First oil change ....................6152kms
New gear transfer case............7400
Oil filter.............................9203
Tyres changed......................10,000
Oil changed.........................12040
Oil and filters changed............16867 ( AMOCO)
New points and plugs..............16888
Tyres changed.......................20250
Oil change...........................20290
Oil and filters changed............24228
New radiator........................28120
Oil changed.........................(Caltex)
Tyres changed.......................30459
Oil and filters changed.............32221
New points...........................33485
Valves ground........................33650
Oil and filters changed..............35702
Oil changed...........................40175
Tyres changed.........................41750
Oil and filters changed...............44289
New seals rear right axle.............44270
Tyres changed..........................45260
Oil changed.............................48103
New plugs...............................49500
Wheel alignment.......................49650
Tyres changed..........................50131
Back diff, gear box, transfer case oil changed.....51124
Oil filters changed......................52174
Tyres changed............................55130
Oil changed ..............................56030
New points................................56793
Oil changed...............................60185
Tyres changed.............................60685
Oil filters and oil..........................64203
Transfer case, diff and engine oil.......75950
Oil changed................................80200
Oil filters changed.........................82237
Oil changed.................................88115
F+R transfer case,seals front diff.........94242
Oil and filter changed......................94536
Oil changed..................................98284
Oil and filter changed......................02329
Oil change.....................................6055
Oil and filter..................................10500
Oil change....................................13657
Front wheel bearings replaced.............22350 June '89
Diff transmission oil changed...............21250 March '89
New manifold gasket..........................24100 August '89
Body work resto and respray..................30,600 Dec '90
Canvas hood repaired, new LH rear axle seals and bearing replaced,changed diff oil, new rear brake shoes....36249 Jan '92
Clutch master and slave cylinder kits .........39400 August .92
New oil pressure gauge sender unit..............39560 August '92
New brake master cylinder, wheel alignment, shockers, new steering dampner......43700 July'93
New front brake shoes wheel bearins, new front springs......45000 Jan '94
New free wheeling hubs....................57000 April '97
Engine reconditioned( rings, bearings,hardened exhaust valves + valve guide seats ect.....58300 Nov '97
All springs retempered with one extra leaf added, new shockers, bushes and pins, shackles ect.........70000 Autumn 2004
New water pump, pass side front spring, new main leaf, new lower radiator hose, radiator cleaned and flushed, fornt diff oil changed,new spark plugs.......81000 June 2005
New fuel pump............................82500 June 2006
New points and condenser................87500 2010
I bought the car 6 months ago and it currently sits at appox 88000
Re: Boredom got to me
Post by pissan »
Some information about the car
1975 MWB G60, was born a convertible, but PO put fibreglass roof on.
Car runs and drives quite well.The only extra option it has is a long range fuel tank.
The car was sold in a place called Leongatha, Gippsland, Victoria, Aus, on the 22nd of august 1975
The car yard was called Yende Motors PTY LTD........................
Hope I'm not boring you yet, so here are the pics so far
Post by pissan »
No more boredom for me................. let the repairs begin
Passenger side floor
Post by pissan »
Right hand side
Post by pissan »
The side steps needed some TLC as well, altho I may not use the original ones yet..
Pulled out the windscreen frame to repair
Post by pissan »
Back of car, above tail lights
LEFT HAND REAR WINDOW
REMOVING LEFT SIDE WINDOW
Post by pissan »
BEHIND LEFT HAND FRONT DOOR
LEFT HAND LOWER DOOR PILLAR
LEFT HAND REAR DOOR
That's what I'm up to so far..New rear door windows are being made, a little progress each day.
Has thanked: 7741 times
Excellent post! :clap: :clap: :clap: I don't find it boring at all. :mrgreen:
Very rare to find a G60 that has not only been so well maintained but the maintenance has been documented.
you're doing a fantastic job repairing all of that rot. That looks like quite a bit of labor. Most would have given up after the first or second spot. Great job! You're going to end up with a very worthy G60 when you're done. :handgestures-thumbupright:
Has thanked: 42 times
Been thanked: 247 times
Post by Johnny Roadkill »
That's something I love about old cars, and old 4wds in particular - they have a long history, and every log book entry, bumper sticker, ding and dent gives a hint as to what they were up to long before they came into my life. :think:
cheers,
D
Post by pissan »
RiverPatrol wrote:Excellent post! :clap: :clap: :clap: I don't find it boring at all. :mrgreen:
Thanks lotssssss mr river patrol I will keep you posted with more pictures of the patrol
