Matt's restro
Has thanked: 27 times
Been thanked: 114 times
Matt's restro
Post by Mattbob53 »
So not ready for paint but some big improvements
We aren't big fans of bondo, so not very good at it, but it's close for paint
Has thanked: 7741 times
Re: Matt's restro
Nice work!
Has thanked: 6027 times
Been thanked: 1607 times
Re: Matt's restro
Excellent work!
Been thanked: 1991 times
Re: Matt's restro
Post by L60Boerne »
Well done Matt, I wish mine could get the same expertise! I am happy with Rafael's work for sure but the rust remaining is another monster for someone else to slay...but I'm working on it.
Keep up the good work.
Matt's restro
Post by Mattbob53 »
Still delaying scraping grease and oil. Did a few smalls this weekend. All powder coated shifter was tuff but turned out well.
Before
After
Re: Matt's restro
Post by Mattbob53 »
My garage finally dropped below 105, so I decided to do some real work. I think I found the hardest nut to remove on the entire truck. What's your guess?? Hint it's part of the front end... and it's still there.....
Rear end is off hoping to get the frame to sandblasting in a few weeks
Has thanked: 42 times
Been thanked: 247 times
Re: Matt's restro
Post by Johnny Roadkill »
Mattbob53 wrote:My garage finally dropped below 105, so I decided to do some real work. I think I found the hardest nut to remove on the entire truck. What's your guess?? Hint it's part of the front end... and it's still there.....
Hmmm...I was thinking tow hook ( I had to cut the bolts off mine with a grinder ), but you did say front end, so...tailshaft to front diff ? :think:
cheers,
D
Matt's restro
Post by Mattbob53 »
The rebound bumper bolts on the front end was the worst nut so far...
On another note my axel seems to have been broke at some point. ImageI called the guy I bought the patrol from and he confirmed. It broke some 25 years ago.. think I should start looking for a replacement?? He drove it for years on it as is... I also have two broken leaf springs, it never ends.. 8).
Re: Matt's restro
They did a good job fixing the axle if it lasted that long. With normal driving it will probably last a lot longer.
Re: Matt's restro
Post by Mattbob53 »
I'm pretty sure I should put this under the quick stupid questions, but from the manual on springs I'm I correct in saying the spring rate on the front 1100 lbs? And rear 1300? I'm a little confused. A lesson in patrol springs would be great before I take them down to the shop to get made.
