78 mwb rebuild
- Has thanked: 51 times
- Been thanked: 78 times
Re: 78 mwb rebuild
hey everone, just wondering, are the floorpans and seating bit the same in a ute and a mwb? thanks in advance
78 mwb softop
- Has thanked: 7716 times
Re: 78 mwb rebuild
78 mwb softop
- Has thanked: 173 times
- Been thanked: 306 times
Re: 78 mwb rebuild
I have a MWB and a ute (LWB). I would say they are the same floor pan, although I have never measured it.
Not sure if I will get there.
Not sure if I will get back.
But I usually do!!!
But I usually do!!!
Re: 78 mwb rebuild
hey all, got back into cleaning today, also pressure washed some body panels to get ready to take to get blasted and primed, things are happening..slowly
shayn
shayn
78 mwb softop
- Has thanked: 6020 times
Re: 78 mwb rebuild
Looks great!
I can't see in the picture if the engine is already painted. What color will you be using?
Re: 78 mwb rebuild
nah not yet proberly paint it tomorrow, well..id like to paint it in that blue colour BUT i already have black engine enamel so will proberly just go that, on a budget after all
will still look nice tho i know not original
78 mwb softop
Re: 78 mwb rebuild
Just purchased 2 sets of extended shackle's from superior engineering in qld aus, so 2 sets mq fronts that is, they are making them for me an I'll have them in a few weeks, can't wait.
78 mwb softop
Re: 78 mwb rebuild
hey everyone, quick question about the body mounts, im noticing that every single mount is different..left 2 are from the cab, others are from the tub, are they ment to be all the same and these have just worn that way? some seem swollen and softer and others compacted and hard but same material...if so, what is the normal thickness for them? thanks in advance!
78 mwb softop
Re: 78 mwb rebuild
They should all be the same. If you're going with extended shackles, you might consider a body lift also. A PO did that on my ute.
