Looking for 63' Brake Cylinders
Parts for sale, or free
Post by Hannah »
I'm looking for the front left and rear right brake cylinders for my 63'. I've looked through the parts lists that have been posted but have not found anything I can use. If you have these parts or know of replacements … or if you have any input on where I might be able to find these, I would appreciate it! I'm trying to avoid converting to disc brakes, mostly for cost purposes, although I would like to keep my Patrol as original as possible (within reason).
Thank you!
Has thanked: 7693 times
Been thanked: 2476 times
Re: Looking for 63' Brake Cylinders
This is the listing on eBay for the front cylinders, the same seller has the rear as well. The listing shows that they're not available right now, but if you contact the seller I'm sure they have some. This is everyone's source for cylinders.
Has thanked: 173 times
Been thanked: 306 times
Post by Peter60 »
They are available on ebay.com.au (Australia)
See
https://www.ebay.com.au/itm/Brake-Wheel ... 1419018581
I have purchased these and they are excellent. Not sure of postage to the USA (often very expensive) or how long it takes..
Not sure if I will get there.
Not sure if I will get back.
But I usually do!!!
Been thanked: 1986 times
Post by L60Boerne »
Yes Yes, I've ordered and received several sets from Australia as Peter60 indicates....then this forum has a thread for your mechanic illustrating the installation thereof.
Post by Hannah »
Thank you for your replies!! I will check this out and get an order going! :D
Has thanked: 264 times
Been thanked: 776 times
Post by plateaucal »
There are modifications necessary to the rear cylinders. Either to the wheel cylinder or the brake shoes. I opted for the latter.
