Has thanked: 149 times
Been thanked: 310 times
Post by G60michael »
Hi Guys, Hope you all had a good week, I certainly did having got a 3rd G60 currently registered. Back in 2017 a mate passed away and I inherited 3 g60s from him, this is 1 of 2 from him that I have since got registered, he would be proud of the achievement.
She is a 1/1977 G60 Patrol Factory Tub Ute with the rare as Tub Style Tub, also known as a G60-62Z (62Z Representing Tub Ute, 94Z is Cab Chassis/Table Top tray)
When I brought her home in 2017, I got her running, the fuel pump was shot so only heard it run for a few minuets at most :lol: since then I parked her in the shed and that's where she sat until a few months ago I Dragged her out to get her ready for the 2020 G60 Trip with my mates to the Vic High country again, having took the shorty last time, I decided a ute would be much less cramped and ideal for a trip.
Plenty of skinned knuckles, cursing and swearing, but once again hard work payed off and I got in there and got the job done, the key to getting a g60 roadworthy is to not sit on your hands waiting for it to fix itself, its to get in there and get it done 8-)
Yesterday she passes a Pink slip for NSW Historic Rego, Give you 60 Days of Personal driving unlimited Km's, Plus other car shows and club events are bonus days you get to drive it. Happy Day's, time to iron out any gremlins before the trip.
This is one of only 2 Known Original Tubs utes that are Registered for legal road use still 8-) The other one is a 1974 Pale Green one in Victoria owned by and old Fella, which i think may now be De-registered
Cheers G60mike
69536954
Has thanked: 17 times
Been thanked: 115 times
Post by PetrolPatrol »
Finally did some work on the Patrol's brakes so I only have to press once. Went with the Wilwood 1" MC for 70-83 Datsun Zs, also fits some 510s and 620s.
This is not the correct size but was extremely close. Close enough that with a dremel I was able to extend the holes in the body to mount it and it only took a few minutes. Sorry, I didn't get exact measurements.
Once in the size discrepancy did bother me a bit, but I discovered that the SU Carb gasket for A-Series engines fits perfectly over it. Cleaned it up nicely and took care of any gaps or what have you.
I had also purchased some NiCop brake lines that included more than enough fittings for this project and a universal GM pushrod kit. The pushrod kit was purchased because the original rod for the MC had no way of connecting to the brake pedal and I couldn't find a Clevis end that would work locally. This kit took care of all of that as the clevis end fits perfectly and the pushrod just needed some minor modifications to work.
This picture is before it was finalized, so the brake lines are backwards. Ignore that :doh: Moore_rb did an excellent writeup on how the brake lines should go and I just followed his lead. Rear to the stock T, fronts to the stock soft line. Once installed and everything was tightened down I used the time honored tradition of trial and error to get it just right. Brakes are firm, stops on the first go, and I feel MUCH better about driving it. I still think I'm going to make some further adjustments in the future but this is good enough for a vehicle with a top speed of 60 MPH.
Not the most in depth write up, but using basic tools and with no adapters or anything like that I was able to get functioning brakes again, so I'm pleased with the results. Just took some time & elbow grease which is no different than any other job on these things (or at least on mine).
Has thanked: 6017 times
Great! :clap: :clap: :clap:
I'm sure other members will find this post really helpful. You've done the right thing. I think functionality beats originality when talking about brakes.
Has thanked: 16 times
Been thanked: 57 times
Post by ozscott »
This week I finally fitted the clutch slave cylinder and new master cylinder (Protex) which, even though it stated was for up to 1980 Patrol, was in fact imperial and not metric. This has been a constant issue with the Protex master cylinders and wheel cylinders. None so far have been metric, all have been imperial, which has meant that I have had to change fittings, and make some new lines, on the brake & clutch system to accommodate. At least I know they are all new and safe.
The clutch slave cylinders available from Protex for G60 Patrols are also imperial, and do not have the mounting holes in the correct position for my 1978 G60. The union at the rear of the slave cylinder is metric on mine, and as the hose was like new I was not keen to add further expense. So I sent the old slave cylinder off for resleeve and rekit. This slave was in very poor condition, the piston rusted (what is the equivalent for alloy into metal?) into the bore, jammed solid, no hydraulic or air pressure could budge it. I was quoted $250 to resleeve, and then found a clutch specialist in Bendigo, Victoria who did the resleeve and rebuild for $75. He will get all my work from now on. He also told me if I could get the dimensions of the clutch slave return spring he can hunt through his stash for one, or get one remade. So, if anyone has the dimensions, Nissan part #46466-44000, and it would appear from the parts book that this spring ran over many years\, I would appreciate it greatly.
In my excitement to finally have all my hydraulic parts for the clutch I forgot to bench bleed the master so now have to pull it all off the truck and bleed the master. :oops:
I hope all of you are keeping well. Self isolation in the shed is like bliss ;)
Has thanked: 173 times
Been thanked: 306 times
Post by Peter60 »
Ozscott
Did you find a return spring? I may have one on a wreck. WIll check next week.
Not sure if I will get there.
Not sure if I will get back.
But I usually do!!!
Got some more minor work done lately. Thanks to the always helpful River_Patrol I got the wiring on my fuse block so it's not always hot and fixed some of the odd wiring decisions of the ghost of Patrol past - cooling fan, fuel pump, ignition, etc. Not original, but better. Installed a fuel regulator and gauge to monitor fuel flow better and make sure I don't flood anything since the Carter carb doesn't like a lot of psi. Small victory but got the spare tire mount fixed as well! Hopefully next bonus I'll have something to mount on it.
Next up is an air/fuel ratio gauge, fixing more wiring, and (I hope) finally getting some rear seats. Then some more interior clean-up and it'll be nice enough (and reliable enough) for top off driving.
Has thanked: 7706 times
Been thanked: 2480 times
Nice Roadster!
RiverPatrol wrote:Nice Roadster!
Thank you. She's got new carpet, an uprated rebuilt 1275, new paint, and is just waiting on me to stop working on the truck so I can rebuild/upgrade the suspension & install new seats.
It's nice finally having a truck! I recently moved and she fits a lot more than the Healey or Fiat could ever dream. Truck ran fantastic, brakes are good, lights never flickered, temps are great, and running back & forth she didn't hiccup once. Since I finally had it running how I wanted I ripped out the fuse block and broke some things.
Finally got the original fuse block installed. Not sure why, but it doesn't match the wiring diagram I have exactly - probably a combination of year changes, no generator, and then some other misc. wiring changes like fuel pump & radiator fan. Slight PITA, but it's much better than what was there. Huge thanks to plateaucal for this one!
Also went full Jeep Wrangler and mounted the hi-lift jack to the hood.
Since that made the hood fairly heavy I decided to add gas struts it. They're two 65lb struts and it lifts the hood smoothly and isn't difficult to lower. I used, what I believe, are two stock holes in the hood to mount them, so it doesn't lift as high as the stock prop, but I'm OK with that.
I also purchased one of the license plate lights off Ebay. It's decent quality, but looking at the paint/rust lines it seems rather small. It also required a lot of modifying to fit, more than I thought it would. Not a huge deal in the grand scheme of things, but if I was doing it again I'd look for one off a true 69 that I knew would fit better.
Now to see what parts I can find to work on next.
Finally changed the battery on mine, after 16.5 years in use. The previous one was a Korean, Solite battery. I was concern that during the winter time the battery might not be up to par. Still was giving 12.67V after sitting for a week, but the reserve capacity was not there.
I bought an Interstate battery, Group Size 34. (Model MTP-34)
Dimensions:
Length: 10-3/16"
Width: 6-13/16"
Height: 7-15/16"
I will say that the contributing factors for such a long lasting performance have been, it's location in the vehicle, outstanding construction quality (never had to clean the posts) and a voltage of around 13.7V that the regulator is controlling all the time. Since it's an electronic regulator, no chance of modifying it.
Evening all, while is haven't had much time to be out enjoying and driving the G60's about due to working and then jobs around the far, but its all good i haven't given up on them, and in fact the collections grown significantly over the last few months with 8 More Parts cars piling up in my paddock :lol: :lol:
About 6 months, I got abit bored and decided to chase up a G60 that was about an hour away abandoned in the Bush, figured it had some good bits :lol: so after Putting out some letters in nearby mailbox's I made contact with the owner, told me its been there the 20 years since he has has the property and dont even know how or who put it there :lol: he said she's Stuffed but you can have it if you want it :lol: so i took up the offer, and while its probably one of the biggest piece of crap I've ever had, actually im sure it was ha ha, it did have some great bits to offer, the tow truck driver even made me sweep down his tray afterwards :lol:
7365
Not Long after My mate Neil, who you've read about on here before, a good mate who lives just up the road who has a g60 farm truck and had a couple of others over time, said to me to come and take away his old G60 that he retired about 18 months ago that he has used for the last 15 years to run his Saw bench and Welder. She was a 1976 wagon made into a Ute, and while she's not the most pretty thing out there bit beaten and worn out engine but still runs and drives, she has some good Rust Free Panels barring a couple of dents, Great Diffs and transfer/gearbox
7366
And then another good mates dad had an old g60 he got to try and fix up, but when it was worse then then he thought he pushed it out into the yard and it sat there for a fair while then he said to me if i want it i can have it, so i took it :lol: She was rough as guts, gun metal grey SWB 1976 model with a ford falcon EFI 250 Cross-flow engine conversion, she also had the H260 rear diff upgrade, Got some good stuff off it, great diffs and drive line, lots of good body parts like handles switches window regulators ect ect, body was cactus
7363
Shortly after a good long time mate of mine who lives about 5km away was having a clean up of his property and he was getting rid of some old cars, he had a g60 and said to me come and take it away, so i did :lol: 1977 SWB, fiberglass Guards, Great motor in it, other then the running gear, shes hasn't got much body wise, but free and good drive line.
73607362
Then about a month ago, went to check out a G60 a couple of hours ago, had carby issues years ago, so they pulled the Air Filter oil-bath off and never put it back on, water got down inside the Carby and filled the engine with water, such a shame and could of been prevented if they just had of tool 2 seconds to put the cover back over it at-least :roll: anyway Scored it, then got her delivered. Great Drive line and interior bits, some under-bonnet goodies still like air snout for heater ect, seat frames are good though they need upholstery, great glass and lots more, 1974 SWB
7356735573547353
Then only a couple of week's back I scored this old Beast, 1974 Black LWB Ute, Bloke about 2 hours away had it, but it was to rusty for him to bother trying to fix it so instead he contacted me seeing if i was interested in buying it, he sent me some details, and his price and said he I can have the car and he will deliver it for an all up total of $150, i said sold. Runs well, needs a tune tho, some great bits, alloy tray, solid original seats, good diffs and gearbox, another good win
735773587359
And Last weekend Home came a couple of more G60s :lol: I got these from the same bloke as a Pair, the Ute is a genuine 1 Owner 1968 model, his dad brought it brand new and used it for many many years for there saw milling company, then she was driven to her final resting spot where she had sat for the last 30 years when rego ran out in 1990. The other is a 1971 MWB wagon, Last registered 2005, but the rolled her into a bank and then she was towed into the bush and thats where she sat ever since. The Ute still had its toolbox in the blokes shed, still has its crank handle behind the seat and the owners manual in the glove box, the wagon also was lucky to still have its crank handle in the back.
However as rough as they are, there very complete and will offer ton's of great parts, best of all i scored the Pair for a bottle of Bundaberg Rum set me back $40, dont often get deals like that anymore these days.
73407341
Went out there Last Saturday to unload the stuff off the Ute's tray and drag the wagon out of the bushes ready for collection the Next Day, and also load a spare motor onto the back of the Ute that they were given many years ago
The Skidder made light work of hauling these old G60s from there previous resting spots. i drove out there in my 1970 SWB as you can see in the background, The fella who had the g60s made some really nice comments about my old SWB and couldn't get over how good it was, and also enjoyed having a good yarn about some of the memories he had as a young fella in his old mans g60.
7342
And Finally The next day (Sunday) had arrived and me and a couple of friends headed off for the day to collect them
7343
7367
and finally there home so here some more pictures for the picture lovers :lol: 7351735273477349734873447350
