GUages
- Has thanked: 203 times
- Been thanked: 678 times
Re: GUages
plateaucal:
Here is the first thread of the new section that perhaps River would create
viewtopic.php?f=2&t=5863
- Has thanked: 7703 times
- Been thanked: 2480 times
Re: GUages
Let me think about how best to place and label it. It has to be clear to newcomers what it depicts. And if for 'true' '69s why stop there when the are uniquenesses for other groups of US Patrols. And it needs to be clear that there are crossover compatibilities, especially with the '68-sold-as-a-'69 so as not to confuse those owners. For instance the hood prop, fender vents and body panels. If you a aren't aware of these similarities you'll just confuse the issue.
And, you know you'll need to include pictures of comparisons, something both of you are the worst about.
Re: GUages
I’m glad you have identified my worst trait!
- Has thanked: 28 times
- Been thanked: 31 times
Re: GUages
RiverPatrol wrote:He needs the later style. Those gauges have the push on connectors, he needs the screw on connectors.
Riverpatrol- Aside from the different connections ( screw on vs spade), do you know if the earlier style gauge cluster would work on my 67 with the screw-on connections? Your wealth of Patrol knowledge is amazing and a true resource to Patorl owners across the world!
THanks (again), Poinrobe
Re: GUages
No, try they won’t. When they changed to the spade connector is also when they introduced the gauge regulator. You an change the connectors but two of the gauges won’t work without the regulator inline in the wiring. Been there, done that.
- Has thanked: 23 times
- Been thanked: 57 times
Re: GUages
I looked at both my 67 and 68 gauges and they both had the spade connectors. When I disassembled the trucks the wiring harness wasn't spliced in either one.
Maybe that's something else they were fuzzy on changing for model years?
Do you know where the gauge regulator is located? I'm sure I have that also.
Located in central Missouri
1966 Hardtop
1964 very modified Hardtop
1967 Parts
1968 Parts
1962 Softy - SOLD
1966 Hardtop
1967 Parts
1968 Parts
1962 Softy - SOLD
Re: GUages
River- do you know where the voltage regulator for the gauges is located? I know there is a voltage regulator mounted to the right internal fender, does this also regulate the voltage to the gauges?RiverPatrol wrote:No, try they won’t. When they changed to the spade connector is also when they introduced the gauge regulator. You an change the connectors but two of the gauges won’t work without the regulator inline in the wiring. Been there, done that.
Again, you are awesome, Poinrobe
Re: GUages
'67 was the first year for the spade connectors on the gauges, and the addition of the gauge regulator. The gauge regulator is not the same as the voltage regulator. It is physically located below the dash to the left of the steering wheel on the firewall. I've identified it in this wiring diagram. This is the diagram for the '69, you can download it here: https://www.60patrol.com/forum/viewtopi ... =32&t=1671
