1969 Patrol, Take 2: Action!
Has thanked: 37 times
Been thanked: 210 times
Re: 1969 Patrol, Take 2: Action!
Post by yitzac1990 »
actually i have a question...i wanna leak test the tank, but dont want to use water, because then obviously the metal will start rusting already. Gasoline is obviously too expensive to waste on a leak test. Does anyone have any suggestions? I might try to pressurize the tank with air instead, but then id have to make blocking plates for the big holes and such. hmm....
...at least that I know of :D
You could etch and seal the inside, which would allow you to leak-test with water, AND would offer the additional benefit of longer overall lifespan for the tank... :think:
https://www.eastwood.com/ew-gas-tank-se ... -cars.html
Has thanked: 6013 times
Been thanked: 1600 times
Excellent work, and some clever details there. Loved the markings done with the welder for the lines. :clap: :clap: :clap:
moore_rb wrote:You could etch and seal the inside, which would allow you to leak-test with water, AND would offer the additional benefit of longer overall lifespan for the tank... :think:
out of stock :( grrrr
Has thanked: 97 times
Been thanked: 568 times
Post by jwgreen »
Has thanked: 264 times
Been thanked: 776 times
Post by plateaucal »
https://www.grainger.com/product/1VNF4? ... 2900016105!
Get some plumbers plugs for the big holes as shown in the link above. Pressurize with air...careful though. Use a hand pump to about 2 psi I would guess. . Install a low pressure gauge maybe with 0.1 psi increments.Then soap and water looking for bubbles. Let sit overnight to see if pressure drops. Keep in mind that temperature fluctuation may change pressure reading.
well the tank is almost done. I have one small leak at the drain plug I put in. I want to "do it right" and empty the tank, take the tank back out, and re-weld around the drain plug nut. Until then, here are some pictures:
my pressure testing rig worked real well!
finished
top view from the Patrol...everything lined up great
bottom rear...
bottom front...
Finished work looks tops! Congratulations.
Did you made the fuel barbs?
the barb fittings I found on ebay, they are 3/8", and apparently made for soda dispenser machines! whatever works, right?
Great find! Thanks
