engine swap
Locked
engine swap
Post by npca-alaskapatrol »
Hey Ok Ok... I know  you, or most of you all are wanting to keep this rig Original.. But  for me here in Alaska,  its kinda hard to do,the shipping charges  will choke a horse. I am wanting to know of anyone that has swapped in a Chevy or GMC 6 cylinder either a 250 or 292,  I remember a pic somewhere  but cant find it  that someone had taken and posted it  but I dont know who  or where I found it. lemme know if anyone has anyinfo on this..  My ol 6 is still running  but il like to put in a more powerful engine  something I can get parts for  easyer.     P.S. Ill get some pictures of my ole`girl on here soon,  befor I start my resto project this summer.And as I go.Ive already started somethings like a Landcruiser rearend  from a 1973.   thanx again for all your extra info on this site. Alaskapatrol
engine swap
Post by npca-gary »
Just a blurb from my foggy memory but a year or two one of the members mentioned that he had a Chevy 292 straight six in his Patrol. A problem he mentioned was the clutch pressure plate had to match the Chevy engine and the Patrol disc and he had to make a spacer to fill in between the engine and the bellhousing.  I think I would also look into measuring the Chev 4 or 5 speed or auto trans and transfer case to see if it would fit the Patrol to minimize hassel. My '69 has a 5 speed (Marks 4wd australia) and it is worth every dime.  Check with Advance Adapters, they sell a conversion kit for the Patrol.           Good Luck,             Gary
engine swap
 Hey thanx for the tip man,  I was wondering where you got the 5spd  got an addy  for that  are there any more avilable.??  also can mabey you look up  who that was or mabey spread the word a lil for me it would really be helpfull.  Also  to those that have rebuilt there p40 engines,, can you please tell me or email me the info on what you did  and where your got the bearings  pistons  rings  ect,, !!  am about to either do a swap or  rebuild this engine, then get to work on the rest of the running gear... any helpfull ideas  would be great  Thanx in advance.   Alaskapatrol. Chaz..
engine swap
Post by npca-roc8man »
I got my engine rebuild kit from Motor Power Inc (Kentucky). Here's the link with all the prices.   http://www.motorpowerinc.com/pricing/p40.html   Worked out fine and the parts are as cheap as a Chevy rebuild.   David
engine swap
Hey thanx alot man!!!!!!  youve just saved me $740 bucks!!  im ordering there kit and gonna get the block bored to improve the power a lil, and i can keep this rig  mostly original.. thanx for the link!. can you tell me  anything about it  the quality and fit? ect  what did u get?   Alaskapatrol
engine swap
My compression was low so I did the rings, all bearings, valves and had the head rebuilt as well. I didn't need a new crank, cam or pistons. If you look at the Compatible Parts section, you will see that you are getting quality items from them (Clevite 77 bearings, chrome rings, Osvat heavy duty valves,...). The entire front end jumps about 4 inches when I let out the clutch due to all the torque. It's awesome. The P40 engine is an industrial engine. It weights about 650 lbs (more than some big blocks) so it is intended to last a long time. Stick with it. Parts prices are not as bad as they once were thanks to a few places that stock rebuild kits for the forklift. Now I just wish I could find a 5 speed tranny...   Btw, where in Alaska are you? I'll be in Anchorage, then Illiamna in late Aug to early Sept (Bow Bou hunt). David
engine swap
David, thnax for your input  man,its a big help.. All ive done to this engine  since bought it in1990, drove it to Alaska, was a head gasket that was about 5 years ago.  rebuilt the distributor once, now I wanna get the electronic setup for it If I can find one, that seems to be the prob right now,,Anyways thanx man if you find anything on where to get a 5spd or something lemme know, Im wondering what other tranny will fit in the Patrol, and lkeep the same T.C,? i havent started looking yet but an soon as i get it un buried from the snow, lol.   And yes Im in Anchorage, bow hunt huh??  thats cool, mabey have ta hookup sometime  say hi!.. Alaskapatrol Chaz
engine swap
No problem. That's why this forum exists. To help us few die hard Patrol fans. The reason I posted the tranny / xfercase question is exactly what you mentioned. I have info for many existing trannies and xfercases but my manual doesn't list what the Patrol has. If I could get that data, then I would be able to compare it to the data I have and maybe find an easy match.    I'll give you a jingle when I get to Anchorage so I can check out your Patrol.   CYa, David
Locked
