Original 60 series Patrol wheels, and substitutes
Original and compatible parts
Has thanked: 2 times
Been thanked: 1 time
Re: Original 60 series Patrol wheels, and substitutes
Post by millerwk »
Thanks again for the recommendation. The tires fit and run perfectly and have all of the traction that I need in the mountains of New Mexico.
Has thanked: 9 times
Been thanked: 21 times
Post by rrbipu »
I need one 15" split ring wheel if anyone has upgraded and has one to sell. I have a set of 4 cleaned up on the vehicle, but I need one to match for the spare.
Has thanked: 257 times
Been thanked: 270 times
Post by Flaggoni »
Sent you a PM
Mild Bill
Been thanked: 6 times
Post by uh34dusn »
EXCELLENT ARTICLE - I need 5 rims on my 1980 Nissan Patrol and don't know if I should get 15" or 16" rims. I found military tires but the rims are difficult to find. Now I have a starting point.
Has thanked: 20 times
Been thanked: 25 times
Post by Scootermixon »
Thanks so much for all the helpful wheel information….that saves a ton of time and searching!
Scott
67 Nissan Patrol L60
Been thanked: 95 times
Post by yuke175 »
Wouldn’t fj40 wheels fit based on the specs?
Has thanked: 6021 times
yuke175 wrote:Wouldn’t fj40 wheels fit based on the specs?
They will. Some members here have used. For many years I had a spare tire mounted on one.
Post by yuke175 »
These may be a good option then.
https://www.cityracerllc.com/products/1 ... -70-series
FJ company also makes a nice modern version but they are big money.
Has thanked: 514 times
Been thanked: 631 times
Post by rdarnell »
I am running FJ40/55 rims dated 1978 on my Patrol as I did not wish to mess with tubes and split rims. I had to make my own hubcaps as I do not like the Toyota hubcap. I cut up a new set of Toyota caps and welded some 1970's Pontiac caps to the bases. I posted some details about the size differences between the 15" Patrol split rim and the 15" Land Cruiser rim.
https://60patrol.com/forum/viewtopic.php?f=7&t=6107
7815
Has thanked: 17 times
Been thanked: 32 times
Post by Frio Patrol »
Someone want to explain these rims??? Looks like they were welded larger.
