1967 Softop Project "Robin"
Been thanked: 95 times
Re: 1967 Softop Project "Robin"
Post by yuke175 »
Shes all settled in the new home.
Has thanked: 7689 times
Been thanked: 2476 times
Looks like it belongs there. 8-)
Post by yuke175 »
Robin has finally come north to sit in the garage alongside the chasis in Massachusetts.
Has thanked: 9 times
Been thanked: 21 times
Post by rrbipu »
That clutch plate has a number that matches this link. Is this a new item that will work? Most folks on here mention having them resurfaced
https://www.nissanpartsdeal.com/parts/n ... n8400.html
Has thanked: 6010 times
Been thanked: 1600 times
rrbipu wrote:That clutch plate has a number that matches this link. Is this a new item that will work? Most folks on here mention having them resurfaced
That clutch disk seems to be for a different model. I'm cross referencing to a 510 Datsun. It's only 200mm, and the Patrol is 275mm in diameter.
Post by yuke175 »
Interesting.
This is a resurfaced plate that came out of the white patrol.
Post by yuke175 »
Finally getting the garage insulated and squared away to get back on this project.
Post by yuke175 »
Making some progress.
I was pleasantly surprised to see how clean the axle was inside. Right now my plan is to replace seals, sandblast, and paint. I don’t think it will need any major work.
I also have a disc brake conversion that a member on here made for me.
Nice that you're finally getting a chance to work on it. There was a discussion on the disc brake mod. Depending on which one you have (there were a couple of different ones) you might want to review it here: https://60patrol.com/forum/viewtopic.php?t=6419
Post by yuke175 »
More progress made. I was able to pull the front axle back out and tear it down.
