Leaf Spring Bushings
Has thanked: 2 times
Been thanked: 31 times
Post by Brand138 »
Hello folks!
I have spent quite a bit of time searching the forums for what leaf spring bushings to buy, but all the links and recommendations I have come across are no longer available.
I specifically need the leaf spring eye bushings, but if available I would like to do the shackle (I believe that's correct term) while I am at it.
Thank you for any information and your time.
Has thanked: 7740 times
Re: Leaf Spring Bushings
I might have some NOS stuff. I'd have to check.
Has thanked: 173 times
Been thanked: 306 times
Post by Peter60 »
Search ebay.
In Australia there are several suspension suppliers:
https://www.nolathane.com.au/
https://superpro.com.au/
https://www.whiteline.com.au/
to name a few. I assume they have similar outlets in the USA.
Generally I find all the suspension bushes etc fit with the exception of sway bar D mounts - they all seem to be too big.
Not sure if I will get there.
Not sure if I will get back.
But I usually do!!!
Post by Brand138 »
Wow thank you both for the info.
I will PM you River :)
