Phoenix Patrol Build Forthcoming
- Has thanked: 233 times
- Been thanked: 165 times
Re: Phoenix Patrol Build Forthcoming
I am having door latch problems too. Is there a difference in the star wheels from early and 66-67?
1967 Patrol
2017 Toyota Tacoma
1968 Camaro
1968 Disneyland Autopia Car
2017 Toyota Tacoma
1968 Camaro
- Has thanked: 6 times
- Been thanked: 1987 times
Bpub, I wish I had some answers for you. I have switched out several types with no luck. I can't imagine how just the 66 year model is fouled up but it can be. It seems som work and some don't.
RiverPatrol does have some answers and he has messed with it before. RiverPatrol...do you want to chim in here?
- Has thanked: 7700 times
- Been thanked: 2478 times
The '66 and '67 were the only years that had the star wheel type latches. They are notorious for wearing out and causing closing issues. Door adjustment is critical to them working properly, including having the proper shims behind the door hinges.
RiverPatrol...this is a new clue so door shims will help. I presume Ready with the Rene can make these. Where to they go...behind the hinges?
They go behind the hinges on the door side of the hinge.
Ok RiverPatrol, so where do you get the shims?
Thank you RiverPatrol, Ready with the Wrench Rene will be challenged this fall after the ATVers vacant out canyon.
- Has thanked: 264 times
- Been thanked: 776 times
L60Boerne wrote:Ok RiverPatrol, so where do you get the shims?
Check your magnificent parts bin. You might get lucky.
I have adjusted the sill plate all the way in and out and when the star clicks to lock the door it still needs to go in about 1/2 inch to close fully. My question would be does the star wheel have only one click to hold the door closed or should there be two clicks. I have messed with them and can't seen to get the door closed fully.
1967 Patrol
2017 Toyota Tacoma
1968 Camaro
2017 Toyota Tacoma
1968 Camaro
