Another old school diagnostic test uses a vacuum gauge. For instance: low vacuum may mean worn rings (will show on compression test as well), vacuum leak, wrong valve timing (slipped timing chain), retarded ignition timing, Oscillating vacuum may mean leaky valve or weak springs. Vacuum that drops steadily may be a plugged exhaust.
Just a thought.
Rough Running Patrol
- Has thanked: 9 times
- Been thanked: 21 times
Re: Rough Running Patrol
Any luck? I can't get mine to stop backfiring un acceleration. I'm working down the list of items. Were did you get your distributor cap and button? I can't find them.
- Has thanked: 48 times
- Been thanked: 151 times
Installed new condenser and points. Seems a little better but still rough at low RPM, runs strong and smooth at higher RPM (>1200). Definitely runs smoother with a little mechanical choke applied.
- Has thanked: 6017 times
- Been thanked: 1601 times
Your timing is probably a bit retarded. Might be at 0 degrees BTDC. Should be at 10 degrees BTDC.Slackd wrote:Installed new condenser and points. Seems a little better but still rough at low RPM, runs strong and smooth at higher RPM (>1200). Definitely runs smoother with a little mechanical choke applied.
