How to remove steering column shaft from steering box
Post by Up2nogood »
Hi guys.
Couldn't find anything on this. Assume I don't have to dismantle the entire steering box? I'm a 1978 built model.
Re: How to remove steering column shaft from steering box
Post by Up2nogood »
I think all models are the same, if that helps anyone?
Has thanked: 6017 times
Been thanked: 1601 times
Up2nogood wrote:Hi guys.
As you said, all models are basically the same. I don't know if there's going to be enough clearance to bring the column shaft out once removed from the steering box, since the steering box will be in the way.
Is there a reason why you want to remove only the column shaft? And if you already did, could you describe how and post a couple of pictures? Thanks.
