Project Tub Ute
Has thanked: 7 times
Been thanked: 21 times
Re: Project Tub Ute
Post by camo75 »
Motor out today and i managed to get the gearbox and bellhousing unit spilt off the enigne
The must be a club i have joined as that was no easy task. :shock: i have removed a few engines over my time but this gearbox setup takes the cake. :D
1975 G60 Patrol Project
2016 Y62 Patrol Daily driver
Proud Patrol Owner past 16 years
Re: Project Tub Ute
Post by camo75 »
Bit of a slower weekend but managed to finish a few smaller jobs. Steering box is completed, painted and bubble wrapped for storage. Starter motor almost completed just need to purchase some glue to refit the sticker to the side.
Fan blasted and painted, fuel cleaned along with the handbrake assembly.
New task while its in my workshop is to clean and paint the clutch housing
Has thanked: 7693 times
Been thanked: 2476 times
Re: Project Tub Ute
It will probably be a few pounds lighter after cleaning all the grime off. :D
Re: Project Tub Ute
Post by camo75 »
Finished off the bellhousing over the weekend. Tapped out the damaged threads, blasted and painted and replaced the grease nipples. Overall pretty happy with how it came out.
Used GM Blue as it seems like the closest i could find to the Nissan color
Ready for storage
There are some brackets on the chassis i was keen to understand if anyone knows what they were for
Re: Project Tub Ute
Nice work on the trans. The brackets are for the exhaust.
Re: Project Tub Ute
Post by camo75 »
Update on project progress.
sadly the previous owner had welded a large amount of steel to the chassis which i found difficult to remove. Under the steel the chassis wasn't in the best condition so i decided to use a donor cars good bits to repair mine.
I cut out the damaged sections and replaced them and i am quite happy with the results.
I know some might comment around chassis mods but short of adding a lot of extra steel and making it look worse i couldn't find a solution to repair that i thought would present well. i may look at welding on some external plate to reinforce the welds but am yet to decide on this
one step closer to sending the chassis away to be blasted
zed
Has thanked: 201 times
Been thanked: 677 times
Re: Project Tub Ute
Post by zed »
Would you have a photo of the frame mounting nuts for the tow hook?
Thanks, Keith
Re: Project Tub Ute
That was a whole lot of steel added! :shock: Looks like you did a great job.
Re: Project Tub Ute
Post by camo75 »
zed wrote: Thu Jul 16, 2026 5:17 pm Would you have a photo of the frame mounting nuts for the tow hook?
Thanks, Keith
Hopefully this helps
