Engine Gasket Kit
- Been thanked: 1 time
Engine Gasket Kit
Does any one know of a source for a complete engine gasket kit for the model P engine? The kit called out in the parts book (10101-58025) is no longer available. I had Nissan Auto Parts.com check it out. Did the gasket sets for the forklift P-40 engines work for those of you who used them? Thanks, Rick G
Engine Gasket Kit
Hey RickG >>Does any one know of a source for a complete engine gasket kit >>for the model P engine? There is a place on the web that lists a kit for the "P" engine, but I dont know of anyone that has actually got a hold of these folks let alone got the kit. Here is the link, if you get ANY info let us know! http://www.tonghong.com/thnis2.htm - >>The kit called out in the parts book (10101-58025) is no longer available. >>I had Nissan Auto Parts.com check it out. Well... the folks at Nissan Auto Parts probally did this, but it may be worth asking to make sure. Via there parts search engine you can type in wild cards, that is to say type in 10101-580%% and it pulls up all the part numbers that have the leading numbers. This is one way of looking for *newer* part numbers that replaced the *older* part numbers. Doing this pulls up the following http://www.nissanautoparts.com/detailli ... mit=Submit Only thing you need to do now is ask the fine folks at Nissan Auto Parts to check the other two numbers to see if any of those still exist. >>Did the gasket sets for the forklift P-40 engines work for those >>of you who used them? Yes and no, good news is the main things like the head gasket, valve cover, etc.. work, but little things like the cam gear cover, push rod cover, etc didnt work. But those you can make a gasket for pretty easily. Grant
