MadTripper wrote:Its the bottom grip of the crutches you need from depressing the clutch....
Name that part!
- Has thanked: 195 times
- Been thanked: 54 times
Re: Name that part!
- Has thanked: 310 times
- Been thanked: 176 times
Re: Name that part!
I'm a bad bad man.
This is a Patrol part and it is decieving. It is a part that one would have to see and touch to fix a brake cylinder....
....it is the protective cap to the Nissan Patrol 30610-10626 brake repair kit.
Re: Name that part!
Chris was the closest.MadTripper wrote:Its the bottom grip of the crutches you need from depressing the clutch....
- Has thanked: 39 times
- Been thanked: 75 times
Re: Name that part!
Haha, not sure I was closest but I'll toss something out...should be easy for most of us but it's all I have from work.
Tripper
Tripper
- Has thanked: 7741 times
- Been thanked: 2482 times
Re: Name that part!
I call foul. Nissan never packaged their kits that way. Maybe whoever you got it from did, but that is definitely not factory packaging.
Re: Name that part!
Oh Great River Master,RiverPatrol wrote:I call foul. Nissan never packaged their kits that way. Maybe whoever you got it from did, but that is definitely not factory packaging.![]()
You have shown me the light...
...and now please allow me to alluminate your path...
It was not easy to justify but you cannot have this kit without this part...so it is a integral and necessary part for a 60....and seems factory? (pg. '71 parts index)...and yes, I'm tricky!!!
Brake shoe adjuster boot clip.MadTripper wrote:Haha, not sure I was closest but I'll toss something out...should be easy for most of us but it's all I have from work.
Tripper
Re: Name that part!
Oh boy...bosque wrote:Oh Great River Master,RiverPatrol wrote:I call foul. Nissan never packaged their kits that way. Maybe whoever you got it from did, but that is definitely not factory packaging.![]()
The kit in the picture above is the brake master cylinder rebuild kit. The NABCO boot in the original mystery part picture is the boot from the kit which is used on the end of the master cylinder when rebuilding it. In the packing list shown it is 46100-27260. It may have been used as a cap in this package, but ultimately it is the brake master cylinder dust cover boot.
Good answer!bosque wrote:Brake shoe adjuster boot clip.MadTripper wrote:Haha, not sure I was closest but I'll toss something out...should be easy for most of us but it's all I have from work.
Tripper
Re: Name that part!
Flappin' "A"!RiverPatrol wrote:The dimension is deceiving. It could be for the clutch slave, or it could be for the brake master.
Technically you are right and there is that #4610027260 on the rim.
Untechnically, that was fun anyhow!
Kind of one of those things we find is ambiguous whether they WERE factory or dealer add-ons or in this case a DIY (BTW!!! the plastic was sealed and I cut it open just for shits a giggles so you guys owe me a brewsky)? Then there were the super uber special factory stuff requested by MrK !!!!!
So....really Master, you are up... but... may I ask what this is?
Re: Name that part!
Great discussion!
This is the result I was hoping to get out of this topic.
Technically you are up because you guessed Tripper's part correctly. I'm assuming...
Again, the dimensions are difficult, but from the weave of the background material this boot looks smaller than the previous one. I am guessing that this is the clutch slave cylinder dust cover/boot.
