Windshield Vents Gasket
Posts by members with instructions on how to do certain mechanical projects.
Has thanked: 6020 times
I've replaced the gaskets on my windshield vents a couple of times, using regular gasket material (weatherstrip) aimed for household applications, found at the regular hardware store.
This idea came some years ago, since these gaskets are very hard to come by, if not impossible. Also, some material that you might be able to source, won't withstand the constant sun exposure as the original ones since they are applied to the frame.
The simple fix was to apply the gaskets to the underside of the vents. Totally protected from sun exposure. They're dirt cheap, and the last time lasted about 8 years, and that time they were foam material. These ones are rubber. No drafts whatsoever, so winter won't be a major issue.
I used: Duck Brand 1282289 3/8-Inch-by 1/4-Inch-by 17-Feet Premium Rubber Weatherstrip Insulating Seal, Super D Profile. I split in half, so the amount of material you have is big. By the way, I started running the length needed for a vent, placing it at the top part, with equal halves overhanging. Separated at that point the protective backing for the adhesive part, and worked my way down, and finally joined the two ends at the bottom middle of the vent. There's so much material and so cheap, that a mistake is easily taken care discarding the whole portion for a vent.
Has thanked: 310 times
Been thanked: 176 times
Re: Windshield Vents Gasket
Post by bosque »
:clap: Thanks a bunch Esteban. Something so hard to find....seems like the silly little things do add up and this one is important. :clap:
:banana-wrench: :banana-wrench: :banana-wrench:
Has thanked: 7712 times
This is awesome information! Thank you Esteban! I made the topic a Sticky so it doesn't get lost. ;)
Has thanked: 173 times
Been thanked: 306 times
Post by Peter60 »
You also can use the idea for side foot well vents, battery cover seal and also as a gasket on the transmission/gearbox cover in the cabin.
Not sure if I will get there.
Not sure if I will get back.
But I usually do!!!
