69' Arizona Patrol
69' Arizona Patrol
Post by AzPatrol69 »
Picked this 69' Patrol up a month or so ago and just now getting around to do some work on it. Has original engine, and is virtually rust free. Came with what I believe are the original front seat frames, no rears. I believe I have troubleshooted it not running or starting to the distributor. Get power to the cap but no spark to the plugs. The distributor looks pretty rough inside, are these able to be rebuilt or is it smarter just to get a new one. If so, where? I'm not very mechanically inclined but I'm trying to learn so I apologize for any future dumb questions I may ask. Feel free to ask any questions about it and I'll answer them as best as I can. Thanks! And I'll upload more pictures asap.
P.S. Love the site and forum, tons of info, many thanks to everyone.
Has thanked: 54 times
Been thanked: 17 times
Re: 69' Arizona Patrol
Post by norville »
Welcome... to the forum.
(insert clever saying here)
Has thanked: 6027 times
Been thanked: 1607 times
Welcome AzPatrol69 :clap: :clap: :clap:
No need to apologize, and every question will be answered by many of the members. Apologies only for politically inclined questions. :twisted: :twisted:
Part for the waterproof distributor are basically unobtanium. Unless you're looking forward to do some serious fording, the easy route is installing the following distributor:
It will mention that it fits the P40 engine. Your Patrol has the P engine. The other is a slightly newer iteration with minor changes. This distributor will fit, and a few other members have gone this route.
Another option with your distributor. If the cap is in good condition, you can install a Pertronix kit, and get rid of the points and condenser which are again, unobtanium. A good cleaning inside the distributor, some oiling, and might be all that you need. The good thing at the moment is that there are options.
We're eager to see some more pictures.
Post by norville »
There's a couple of options start with the points, are they opening and closing when the distributor is turning? Pertronix sells a pointless kit for these, another option is to buy a new dizzy form a nissan forklift. Start with the basics... power, ground ect.. I'm not sure if stock points are still available. I know many points wear the rubbing block out before the point pad is gone.. very common problem.
info thanks to Esteban,bosque and RP
http://www.60patrol.com/forum/viewtopic ... onix#p8157
Do you have any more pics?
Post by norville »
Ha, I'm a really slow type-er I still got the welcome in first...Don;t worry we'll get ya moving if possible.. these are very simple engines..
Has thanked: 310 times
Been thanked: 176 times
Post by bosque »
Alright AzPatrol69. Looks like you are ready to paint!!! Use this site like ya own it.....cause you do. I have asked all the stupid questions so if you wonder do a search and you'll get the answer and if not ask away. :clap:
Couple more pics. The points are opening and closing when the distibutor is turning. the wires look a lil shotty, and there is a lot of rust as you can see.
And, yes I do have the contact point that goes on top of the screw on the distributor, I just had it off for the pictures.
Post by bosque »
Rip that crude out of there and replace with this electronic doohitchy we have lots of info on here....just search pertronix .....you have a waterprotect diz (3-screws vs 3 clips on cap) so you need a #1763. Good luck.
Post by norville »
if it's hot to the cap check the condenser, how are you determining you have spark up to the cap? Is ther power on your coil? coil could be shot.
