Cleaned glove compartment out.........hmmmmm
- Has thanked: 85 times
- Been thanked: 97 times
Ok, cleaned the glove compartment out and found the following stuff/parts. Other than the obvious (Broken rad cap), is some of the stuff Patrol related?
- Has thanked: 310 times
- Been thanked: 176 times
Re: Cleaned glove compartment out.........hmmmmm
Two gray heater doors, football shaped exauhst gasket, ....I'll take a stab at the top shot lower right is maybe a seat release latch and the broken handle. Spring could be from the horn button but should be brassish color. The rod with bracket could be a side mirror.....guessing.
Should have shown these on "Name that Part"
lol..........I thought about it. Thanks for the input.
- Has thanked: 7740 times
- Been thanked: 2482 times
The triangular gasket goes between the intake and exhaust manifold. The heater box doors, the exhaust pipe gasket and the two pieces of the seat latch are the only other recognizable Patrol items.
The rod/plate thing is vaguely familiar...
- Has thanked: 529 times
- Been thanked: 301 times
The two black rubber "posts" and the soft gray cloth gasket half round are most of a rear main seal for the P motor block. The half round should have another half to go with it. One half fits up in the block and the other half fits into the rear main bearing block. The two rubber posts slide into cut out grooves on either side of the bearing cap and the engine block.
Jeff
50Car
50Car
