M416 Trailer
Has thanked: 39 times
Been thanked: 75 times
M416 Trailer
Post by MadTripper »
I'll have to get some photos however, I started working on my trailer this evening to add a tailgate to my M416. I use it quite a bit around the house but not having easier access made it a bit more cumbersome than I cared to have.
Originally, the trailer was designed for the military, I think during the Korean conflict and some in Vietnam. The max capacity was set to 500 lbs but only because the limit was what 4 soldiers could carry. The axle and springs are easily 3500 lb capacity. There are handles on each corner and by removing 6 bolts, the whole tub would lift off the frame and also provide some flotation for crossing small streams and rivers. That isn't necessary in my world however having the ability to easily add and remove mulch, wood, gravel and dirt is.
So this is what I started with:
I'll update before long but I basically have cut most of the back plate off, added angle iron on the bottom using the existing bolt holes in the frame, and square stock as the risers. I'll hopefully continue progress tomorrow and I hope to give it some paint and possibly use bed liner for the interior. I also need to get the parking brake functional. It is in pretty decent shape considering but I think the multiple coats of paint have helped over the years.
Just for fun!
Also, if anyone has experience with rim size on these things, let me know. I need to toss some other setup on there so I can get my inspection done.
Tripper
Has thanked: 104 times
Been thanked: 175 times
Re: M416 Trailer
Post by Swerve »
I reckon a SOA converson to start with, but I like it
Has thanked: 310 times
Been thanked: 176 times
Re: M416 Trailer
Post by bosque »
Looks like you use it for yard work stuff. I wonder if it is possible to make it dump via a lever....?
Has thanked: 54 times
Been thanked: 17 times
Re: M416 Trailer
Post by norville »
I think you should give it to me...
(insert clever saying here)
Has thanked: 7706 times
Been thanked: 2480 times
Re: M416 Trailer
Those are pretty popular and very handy trailers. I have seen them converted to camp trailers. I had one a while ago and people were lined up to buy it.
Has thanked: 84 times
Been thanked: 327 times
Re: M416 Trailer
Post by miller »
Ive said this many times but jeez I love these little trailers! I'll be watching with interest.
Re: M416 Trailer
Welder was acting funny but I managed. Hopefully get more completed tonight.
They do have a ton of different configs out there. I may add some things in time but for now just utility. I have seen one converted to a dump that was pretty neat.
Has thanked: 59 times
Been thanked: 56 times
Re: M416 Trailer
Post by azsteve »
MadTripper wrote: Just for fun!
What an awesome picture!! I think you should put a trolling motor on the list of mods!
1966 L60 Patrol
"Hey, watch this...!"
-probably what my last words will be.
Re: M416 Trailer
I think I'm going to latch it similar to this except 90 degrees off for the eyebolt. That way the bolt will give a little support for the sides as well.
Re: M416 Trailer
Post by miller »
Oh I see, so that ring pulls out and twists to lock into the grooves. Looks sturdy. If your tailgate was to get dinged when carrying a load will the eyelets have enough "give" to still line up?
