Door Pin Removal
Door Pin Removal
Post by npca-pudde »
wd 40 the pin...once its loose...you have to remove the door opening limiter on bottom(if you still have it)..then open the door all the way..almost to the body...and at that point..you can wiggle it back and forth..pulling up on door at hinge area...and it will come off...but..door has to be open all that way(youll see if you dont..its like an interlocking tang that prevents it from coming off from being just oepened normally) pins should stay on body half of the hinge....if its broke..just tap old pin out...its easy..i did it with mine..and the hood hinges as well... paul :)
Door Pin Removal
Post by npca-lmtshootingstar »
When I bought my 69 the pins had been removed and some long bolts installed....but they are loose.  Anyone know of of replacement for those stock pins?
Door Pin Removal
Post by npca-67l60 »
any good machine shop can make the they are exactly the same lenght as the hinge and the lower hinge hold pins via a crimp that way you lift up the door,s to remove and the pin stays constantbe shure to grease the heck out of them regularlyor they will get stuck in a hurry
Door Pin Removal
; I have no original pins to get a dimension from.  I ; guess I could take a door in. ; ; ; From: npca-67l60 [mailto:j.wilhite@mchsi.com] ; Sent: Tuesday, October 23, 2007 4:54 PMTo: Nissan Patrol ; Club AlbuquerqueSubject: Re: Door Pin Removal; ; ; ; ; ; New Message on Nissan Patrol ; Club Albuquerque; ; ; Door Pin ; Removal; ; ; ; Reply; ; ; ; ;  ; Reply to Sender   Recommend ; Message 12 in ; Discussion ; ; ; ; ; ; From: npca-67l60 ; ; any good machine shop can make the ; they are exactly the same lenght as the hinge and the lower ; hinge hold pins via a crimp that way you lift up the door,s to ; remove and the pin stays constantbe shure to grease the ; heck out of them regularlyor they will get stuck in a ; hurryView other groups in this ; category. ;
Door Pin Removal
ILL GET YO SOME ACCURATE DIMENSIONS TOMMOROW
Door Pin Removal
; Wow, thanks for going through all the ; trouble.; ; ; From: npca-67l60 [mailto:j.wilhite@mchsi.com] ; Sent: Tuesday, October 23, 2007 9:05 PMTo: Nissan Patrol ; Club AlbuquerqueSubject: Re: Door Pin Removal; ; ; ; ; ; New Message on Nissan Patrol ; Club Albuquerque; ; ; Door Pin ; Removal; ; ; ; Reply; ; ; ; ;  ; Reply to Sender   Recommend ; Message 14 in ; Discussion ; ; ; ; ; ; From: npca-67l60 ; ; ILL GET YO SOME ACCURATE DIMENSIONS ; TOMMOROWView other groups in this ; category. ;
Locked
