I wanted it to look "factory" so im using a spare wheel carrier i have for the base.
First off i cut up the top bracket so it could be rearranged to suit the drivers side. I also had to cut the bottom out of it and flip it over as the hole is offset.
All welded up
Measured out the bottom bracket and bolted it on for now. I needed to weld a spacer on the bottom bracket as the hole had become elongated, i have left some room for more shims so the fit can be fine tuned later.
Next cleaned up the locating pin from one of my parts rigs and welded it to the tub. The steel is nice and thick along the bottom rail so i was able to get a strong weld. As you can see i am improving, i just need to try and keep my lines straight!
and finally the mock up. I havnt got a photo since its all been welded in place but this gives you a ruff idea of my plan!
Tomorrow i will build a frame to strengthen the tub. Here is the dual jerry can holder i will probably be using..
