NT 60 Patrol hunting rig project
Has thanked: 7696 times
Been thanked: 2477 times
Re: NT 60 Patrol hunting rig project
G60michael wrote:Image
:lol: :lol: :lol:
Good one! :lol: :lol: :lol:
I think he also needs an award for the least amount of floor space. :D
Been thanked: 4 times
Post by tripod »
We've been checking over the car for things that might need attention if it gets going one day. One thing was the LHS locking hub. Have asked some question in the Engine and Mechanical section and rekon we have figured out what to do but here is another picture of the busted hub looking from the inside. Its was jammed and the switch couldn't operate so the hub was stuck in the unlocked position. 2 of the small bolts were bent pretty badly and needed the heads drilled off to remove this part. Looking inside there are several cracks around some bolt holes. Not sure if simply putting it back on with it in the locked position will work under load but I guess there is one way to find out.
Post by tripod »
Something of interest is the square section pin at the base of the door pillar. Also wandering if she has fallen off of a high lift jack at some point or if someone didn't find the proper jacking point :)
Have it welded, brazed or this has impressed me.....no welder needed 30,000 psi. http://muggyweld.com/super-alloy-5
I believe the square peg to be a base male piece for a 1" x 1" square tube vertical support for a roof rack. I'd use it!
Post by tripod »
I think you might be on to something with the roof rack idea. There is another peg on the drivers side and another 2 pegs at the rear, one in each of the rear corners.
I'd drill a fat cotter pin or bolt through the assembly to fasten.
Post by tripod »
Well fella's................she runs!
3rd turn and there was a fire and by the 5th turn she was running. If it wasn't a Nissan I'd say it was unbelievable. Sounds like an animal and nearly choked us all with the exhaust coming up through where the floor should be in a nice afternoon of 37 degrees, after we had waited all day for it to cool off a bit.
I'm still grinning. So happy it goes and so now I think we'll fix the clutch and see if we can get her mobile again. So, now before I get any grief, even if friendly :D , about things not existing without pictures. I will charge up the gopro and see if I can get a video onto youtube of it running just because it sounds so cool and that I rekon you guys on the forum would get a kick out of it. Just give me a bit to get it done. Runs loud and lumpy, nothing really pleasant but nothing making any rattles or knocks .......yet!
Cheers
Has thanked: 149 times
Been thanked: 310 times
Post by G60michael »
Awesome love to hear it running. This usually seems the case that if an old G60 still got compression, Oil, Fuel and Water there is 98% chance it will sill work :clap:
Also check you Hotmail Emails
Has thanked: 84 times
Been thanked: 327 times
Post by miller »
tripod wrote: So, now before I get any grief, even if friendly :D , about things not existing without pictures.
We're a predictive bunch ain't we?! Haha :laughing-rolling:
Congrats on getting it running though. Well done :handgestures-thumbupright:
Too cool! Can't wait for the video! :D
