I'll try to work on it this next week.RiverPatrol wrote:He's using an iPad, so it's a little trickier.jwgreen wrote:Guess I need to do a video on posting links2869ral wrote:I dont know how to drag the ebay link here, but they are from ultimateindsolutions they are out of Maryland seals are $5.98+$3.95shippimg.![]()
Seals: transfer case input-output, pinion.
- Has thanked: 97 times
- Been thanked: 568 times
Re: Seals: transfer case input-output, pinion.
- Has thanked: 6022 times
Got me thinking, because I know the struggle the Ron has been facing. This is what can be done. A similar procedure will work for the iPhone.
Take a look at the picture below from the screen of an iPad (please note that the link of the actual page is nowhere to be find)
Step 1: Select the symbol at the top (arrow #1), that opens a dialog with a number of options.
Step 2: Select Copy (see arrow #2). This action copies the link of the page.
Doing the above, the following is the link from eBay to the Double Lip Seal 50x73x12 that Ron found.
http://www.ebay.com/itm/Metric-Oil-Shaf ... 1127460009
- Has thanked: 7718 times
Esteban, you're so awesome.
How to copy and past links using an iPad or tablet
To expand on Esteban's post
Go to the website and item that you want to post
Tap the little box with arrow and then tap Copy Now return to 60 Patrol post
Select the URL button in your post Select the cursor in between the [url] brackets then Tap Paste Now you can select Preview And your link should show up in Blue Hope this helps and is a little easier to follow.
Justin, you're even awesomer!
Thanks Leslie, I'm just tying to impart what little knowledge I have to this site.RiverPatrol wrote:Justin, you're even awesomer!![]()
- Has thanked: 181 times
- Been thanked: 174 times
This seal is still available from Nissan. Couple winters ago I walked into Napa here in my tiny little town with the seal in hand. They called their Nissan dealership they get parts from, didn't mention truck it was for but read the number off the seal. Two weeks later I had a set of seals from Nissan. Recently I have bought more of them, directly from Nissan.
Cheers
Cheers
What part number did you order?
38189-44000RiverPatrol wrote:What part number did you order?
http://www.amayama.com/search?region=315&q=38189-44000
Cheers
I ordered the following seal from eBay just to have in stock:
AVX Shaft Oil Seal TC50x73x12 Rubber Lip 50mm/73mm/12mm metric (use this for the search)
http://www.ebay.com/itm/AVX-Shaft-Oil-S ... 5d60384466
It's not double lipped as the original (to keep oil in, and water out). It does have an outer lip that will keep dust out. Will work if you're not fording any streams.
