Removing buggered Hub nuts
- Has thanked: 12 times
- Been thanked: 36 times
Re: Removing buggered Hub nuts
if you are good with a cutting torch it is possible to cut a nut away from a threaded shaft without buggering the threads. this won't be as easy because you will have blowback slag to deal with. but it can be done. i like Swerve's idea if you have a drill that will get to it. a dremell tool with a cutting blade might work too, if you have a flex shaft to go with it. i have one and love it. i would cut two slots on opposite sides, and it should cause no problems coming off.
1967 SPL 1600
2013 Nissan Rogue
2001 Nissan Sentra SE R
2013 Nissan Rogue
- Has thanked: 6023 times
- Been thanked: 1605 times
I like Miller, Swerve and Sleepyzzz ideas. If you can drill a hole, try using a rounded tip cold metal chisel. A good blow with it in the hole could split open the nut.sleepyzzz wrote:if you are good with a cutting torch it is possible to cut a nut away from a threaded shaft without buggering the threads. this won't be as easy because you will have blowback slag to deal with. but it can be done. i like Swerve's idea if you have a drill that will get to it. a dremell tool with a cutting blade might work too, if you have a flex shaft to go with it. i have one and love it. i would cut two slots on opposite sides, and it should cause no problems coming off.
However, I have a big concern. If due to the damage or wear of the bearing the hub was able to grind the nut, so to speak, what other problems you might find inside, that are possible beyond repair. The bearings could have rotated in the spindle. In addition, you'll need some fresh parts that can add up in cost significantly. But I guess you'll want to know it anyways. Otherwise, use option 1. It's going to take the least amount of time.
G60michael wrote:Guys I've come up with 3 options, the one most preferred will get the most chance of getting done....
1: Remove whole diff and springs together and swap in a Diff ad springs together from neils wreck. (That fixes bearings and springs issue, Heavy work)
