NISSAN PATROL MANUAL
; ; ; Hi Peter; Thank you verymuch for the information ; furnished.I will be grateful if you can further help with ; any other supplemental information.I give below ; what I have already done.; ; 1) How can I recharge the viscous fan?; 2) The Fan blades are fairly O.K. excepting a ; couple of minor cracks on the hub.; 3) thetransmission oil cooling radiator appers ; to be in good condition.; 4) I opend the radiator and thoroughly cleaned ; up. There are no blockages or leakages.; 5) I have already done this. The vehicle runs on ; city roads and are not blocked.; 6) These areas are clear.; 7) I have already checked but I will recheck ; this again.; ; I will be happy if you can put me on Newsletter ; email list.; Thanks,; Rao.; ; ; ----- Original Message ----From: 4x4peter ; To: Nissan Patrol Club ; Albuquerque ; Sent: Saturday, March 20, 2004 11:40 ; PM; Subject: Re: NISSAN PATROL MANUAL; ; ; ; ; New Message on Nissan Patrol ; Club Albuquerque; ; ; NISSAN ; PATROL MANUAL; ; ; ; Reply; ; ; ; ; ; Reply to Sender Recommend ; Message 9 in ; Discussion ; ; ; ; ; ; From: 4x4peter ; ; ; Hi Rao; ; C = High roof Station Wagon; R = TD42 engine (4.2 litre Diesel); G = long wheel base; Y60 = Model = Nissan Patrol Y60 series; PKTAZ = vehicle serial number; ; 1993 = ???? can't tell from info I have; ; ; You may find all your problems stem from running to hot. ; The Nissan GQ Patrol diesel TD42 has does develop overheating ; problems.; 1. The viscus fan unit fails to function properly, either ; get it recharged with oil or replace.; 2. The Fan blade develops radial cracks between blades and ; distorts so does not move so much air, replace.; 3. The transmission oil cooling section of radiator maybe ; partly blocked put in aftermarket oil cooler and service ; transmission.; 4. Check radiator core is not blocked and get flushed as ; necessary.; 5. Radiator fins blocked (mud/grass etc.) clean out as ; necessary.; 6. If the transmission is overheating chech for mud/grass ; etc arround transmission which will inhibit cooling air ; flow.; 7. Check correct tension on fan belts.; ; If you are new to four wheeling or just setting up your ; truck then the TECH HINTS section of my website http://equip4.co.nz this ; site is basses arround Nissan patrols in New Zealand. We also ; have a range of recovery gear along with a gallery and a ; technical hint section, have a look and if it is of interest to ; you email me and I will put your name on the Newsletter email ; list for future ; updates.Peterequip4.co.nzView other groups in this ; category.
RAO.................... the model of your Patrol I cant tell you from the chassis number, but I can tell you this.... the model is the G60............. the engine is the venerable T42 diesel aspirated engine 4.2 litre inline 6, still built and used on the Y61........ so you can find plenty of parts for the engine. Ill see what I can do about the wiring diagram..... To find out the year model A picture would help a lot. Down here in Paraguay a lot of G60´s are running so parts are available... I had one G60 for ten years and trade it for a Y61........both with the T42 engine Youve got a heck of a truck!!!!!!!! Send me the pictures of your truck and Ill see what I can do Rod
Rao One more thing..... does your Patrol come with the dual Air Conditioning system or just the regular one Rod
