Axle rebuild guide?
Been thanked: 95 times
Re: Axle rebuild guide?
Post by yuke175 »
I am having trouble finding the bearing #9 in the parts list. Can anyone help point me in the right direction?
I found here at the forum the following post by member faux40 where he cross references that bearing # 40588-44000 to a RUS305
https://www.60patrol.com/forum/viewtopi ... &start=870
Bearing RUS305
Size (mm) : 25x62x17
Brand : NTN
Bore Diameter (mm) : 25,000
Outer Diameter (mm) : 62,000
Width (mm) : 17,000
At Grainger:
NTN Cylindrical Roller Bearing: 305, 25 mm Bore, 62 mm OD, 17 mm Overall Wd
Item 4ZXW4Mfr. Model NU305EG1C3
Please take some measurements of the original bearing first to double check the above info. And if everything matches, we'll add this to the compatible parts list.
